Rocky-Road Rocker Protectors (I bought a set)
So I was on the fence trying to decide between Rocky-Road or OEM rocker protectors. I went with the rocky-road and I couldn’t be happier. These things are heavy…. heave duty, with out a doubt. (they also come with a life time guarantee not to bend, dent, break) Holes lined up perfect, it was a tight fit on the side with the e-brake but it fit. One issue I had was two of the threaded holes in the frame that have never been use had to be tapped. I started the bolts and it started to get really tight I backed em out and the threads were jacked up. I had to pull out the tap and die set and clean the holes and rethread the bolts. I also used some blue lock-tight on all the bolts. On a scale of 1-10 they are a 10
RE: Rocky-Road Rocker Protectors (I bought a set)
Crap! I could've used this thread a week ago as my OEM rockers are on their way. A lot of people I talked to said the RRs didn't fit correctly...guess that's not the case. Your's look awesome! You should send the close-up pics to RRs, so they can post a good H3 example on their website. I may consider a return now Thanks for the info.
Khrome
06-26-2011 10:23 AM
dinov
07-22-2010 01:25 PM
skeeet
03-31-2006 04:14 AM
