Hot seat
Old 02-01-2014, 10:40 AM
Greg French's Avatar
Default Hot seat
Need help,
I have a 2007 h2 SUT. I have no movement on the drivers side seat adjustment and no heat on either. I have checked all fuses inside and out. Any advice?
Greatly appreciated.
Greg
Old 02-02-2014, 11:37 AM
happythree's Avatar
im an h3 guy but you need to pull the connectors and check volts under the seat. its going/not going somewhere. could still be a circuit breaker.
unplugging the conn is a learning experience but can be done.
on a h3 the c breaker is on the seat bottom
Old 02-03-2014, 02:28 PM
Thanks for the heads up, I think the circuit breaker is in the centre fuse box in the H2.
Thanks for your help.
Old 02-03-2014, 04:53 PM
happythree's Avatar
jfwiw, the h3 has a 40 amp fuse, then the seat mounted cb, because it feeds the passenger seat from the driver seat.
jstdoitt21
01-28-2009 12:50 AM
Quijy
10-20-2008 07:30 PM
Nxsov180db
06-06-2008 06:45 AM
Quick Reply: Hot seat
