front differential top up - Hummer Forums - Enthusiast Forum for Hummer Owners
General Hummer Talk Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Old 10-13-2007, 06:29 PM
Default front differential top up
Hey guys. I was checking the differential fluid level today and I know the owners manual says the level should be half inch below the bottom of the fill plug when cold. If I put my baby finger in there, I cannot put it in far enough to get to the level. Should I just fill till fluid starts to come out the hole that way I will know it is full? Does it matter what fluid I use just for a top up as long as it is 75-90 synthetic? Thanks in advance.
Old 10-14-2007, 12:33 AM
Default RE: front differential top up
While tonight I topped up the front diff. with castrol syntec 75-90. Would anyone have a manual that would show the torque for the fill plug on the diff? For now I torqued it at 25ft/lbs. Thanks
Old 10-14-2007, 10:03 AM
Muddydawg75's Avatar
Just snug the plug up.... tight is tight... it really doesn't need to be torqued.
I fill mine until it comes out the hole.... about 2 quarts for the back.... and about 1 3/4 for the front. (from empty)
One small piece of advice.... always make sure you can get the fill plug out before you remove the drain plug.
Old 10-14-2007, 06:34 PM
This time I just topped it up. I don,t know when it was looked at last but it took almost half bottle. I will keep an eye on it now. i have only owned this H2 for about 2 months .I love it.
Old 10-14-2007, 07:56 PM
hilljob26's Avatar
every diff is about the same,fill it up till it comes out the hole,then just give the wrench a good grunt,like muddy said,tight is tight,theres no load on this so torque shouldnt really applyas long as its tight
rijowysock
Hummer H1
03-07-2013 07:57 PM
upholstryguy
06-17-2010 09:35 AM
Nxsov180db
06-01-2008 02:47 PM
HingHum
06-13-2007 07:12 PM
vinceau911
Private 'Wanted' Classifieds
12-19-2006 05:08 AM
Quick Reply: front differential top up
Advertising
Featured Sponsors
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
