Flat tire
Flat tire
So, today I have a flat. It seems the dealer took my key (and kept it) to get the spare off last time I had them fix a flat. So I can't get the spare off. OK.
Next, I jack the thing up and remove the nuts and the tire won't release from the hub.
Why? I can't see where there is a lock on any of the bolts that held the lug nuts.
Anybody know?
Anybody know?
Tried everything to get the tire off. I finally used penetrating oil to break it loose. The only tire that has a lock is the spare. My Hummer H3 has 42000 mile and I could not believe the rust on the hub that has ate into the my chrome rim from behind. It isn't visible from the front yet but will be in a short time. If all my rims are like this, that sucks big time. I tried a rust remover but it only worked about half way. I am going to take off every rim and see if this is happening. I baby my Hummer keeping the body and rims in wax. Looks like that has been a waste for the rims.
Oh, and the key isn't in the package marked key lock in the spare kit. It is in one of the compartments of the jack. If I had used the tools the Hummer came with; I probably would have found it.
I do not live in a big city where crime is a problem so the first thing I do on any new car is get rid of the locking lug nuts, even on the Corvette. I have had them fail once when they fractured (stripped) and it was very difficult to get it off the wheel. That is not something I would want to happen in the back country.
I believe capillary action draws water inbetween the wheel and hub where it can not dry out plus sometimes two dissimilar (steel and aluminum) metals can cause corrossive action. It is not a good idea to put grease or oil on the hub face or on the lug studs. Grease on the studs will not give you an accurate torque value- hope you are torquing it to 100 ft/lbs?
