Best Battery for H3
Best Battery for H3
Hey guys, so I've been noticing that my 2007 H3 battery has been weak. Didn't die on me yet but every morning as I start it , it starts weak, then if I try again after a few mins, its fine. I am assuming it's about time. so what is the best battery that is recommended for a 2007 H3??? I know the rule of thumb is squeeze the biggest u could find, but no , I dont want to do that. So which one is the best that I could fit in normally?
thanks guys
thanks guys
you may have a good batt and something pulling it down overnight.
normal drain is 110 milliamp, apx 1/10 amp. it doesnt take much to kill overnite. be sure all lights go out!
you check by closing down,unhook 1 batt lead,use a digital meter on amps. it will jump up to 1-2 amps briefly,then settle at 110 ,ma.
any batt that fits is fine,its not fussy. i use big ones.
these things start/run so good it dont take much batt. the gen does the work.
omarluna2
22
12-25-2018 10:01 AM
brachilius
07-17-2006 11:28 PM
