aftermarket head unit work with onstar?
does an aftermarket head unit like a touch screen work with onstar? just wondering.
if not how will it? can i install and just cancel onstar.. how does this work? |
RE: aftermarket head unit work with onstar?
You can do EITHER ONE!!!
You can just NOT USE OnStar or you can get a PAC interface. It all depends IF you keep the factory amp etc. as to which one you need: http://www.pac-audio.com/products/pr...ar%20Interface I think mine was the OS-2 since I replaced EVERYTHING from HU, amp and speakers!!! |
whT DO YOU MEAN KEEP FACTORY AMP ETC.. I DONT NEED TO CORRECT?
i do not have monsoon, i just have a small aftermarket sub and amp. so i can just plug a new head unit in and go? just cancel onstar? |
ORIGINAL: JeepeaterH3 whT DO YOU MEAN KEEP FACTORY AMP ETC.. I DONT NEED TO CORRECT? i do not have monsoon, i just have a small aftermarket sub and amp. so i can just plug a new head unit in and go? just cancel onstar? |
i thought you still needed a special harness for the door rings and such
Get a Pac-os2
ORIGINAL: hilljob26 i thought you still needed a special harness for the door rings and such |
