Installing wheel studs...
My aftermarket wheels have a very narrow mounting hole for the lugs. TireRack included lugs and a thin wall socket which is a pain in my ***. Anyway, I threw the 2 on jackstands to bleed my brakes with my new pneumatic brake bleeder. In the process the front driver wheel resulted in 1 broken stud and 2 studs where the threads were destroyed but I got those lugs off.
I don't know if they are just cheap lugs or what. Anyway I picked up new studs from Checker and popped them in. However I cannot get the bastards seated all the way. I bought some spacers and put a stock lug on to try and pull the stud in that way, ended up destroying the threads. Luckily I bought extra studs just in case something like that happened.
Any ideas on getting the studs completely seated? I did all of this with the hub still installed. I'm assuming the recommendation will be to remove the hub and have them pressed in?
Thanks in advance.
Thanks in advance.
davyo
05-12-2008 11:38 PM
BahamaTodd
01-25-2008 03:48 AM
