Does anyone know about blue-tooth scanner
Goliath Industry Wireless OBD2 Car Code Reader Scan Tool
Connects Via WiFi With Any IOS, Android & Windows Device
4.6 out of 5 stars 118
This scanner uses the "Torque App" for Android phones. When I hooked it up
to my 2008 H3 Alpha and loaded the App I find It's not talking to the E.C.M.
Then checked to see if it would work on my HHR... got the same thing.
Could use some advice from someone that has used a blue-tooth scanner
Dave P.
Dave P.
Dave P.
Dave P.
You could have a bad device or you are not following the proper sequence in getting the device to bind to your phone.
Everything from plugging it in to turning the key to certain positions at the right time all are required to make the connection.
Amazing
I was looking to see if anything would jump out and say REPLACE: PCM or ECM
the shop should be able to figure it out.
Mode $06 report generated by Torque for Android
Test report:
MID:$01 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 165ms Min: 0ms
Test result value: 30ms
PASS
MID:$01 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 120ms Min: 0ms
Test result value: 22ms
PASS
MID:$01 TID:$80
Max: 65,535Changes Min: 48Changes
Test result value: 232Changes
PASS
MID:$01 TID:$81
Test result value: 233Changes
PASS
MID:$02 TID:$8a
- O2 Bank 1 Sensor 2
Max: 1,450Count Min: 0Count
Test result value: 89Count
PASS
MID:$02 TID:$8b
Max: 1.10068V Min: 0.81045V
Test result value: 0.89402V
PASS
MID:$02 TID:$8c
Max: 0.10004V Min: 0V
Test result value: 0.05893V
PASS
MID:$02 TID:$91
Max: 0.45018V Min: 0V
Test result value: 0.376V
PASS
MID:$02 TID:$92
Max: 1.10068V Min: 0.35014V
Test result value: 0.38967V
PASS
MID:$02 TID:$93
Max: 8 Min: 0
Test result value: 1.19
PASS
MID:$05 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 2 Sensor 1
Max: 165ms Min: 0ms
Test result value: 33ms
PASS
MID:$05 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 2 Sensor 1
Max: 120ms Min: 0ms
Test result value: 24ms
PASS
MID:$05 TID:$80
Test result value: 248Changes
PASS
MID:$05 TID:$81
Test result value: 247Changes
PASS
MID:$06 TID:$8a
- O2 Bank 2 Sensor 2
Test result value: 59Count
PASS
MID:$06 TID:$8b
Test result value: 0.90768V
PASS
MID:$06 TID:$8c
Test result value: 0.07064V
PASS
MID:$06 TID:$91
Test result value: 0.30524V
PASS
MID:$06 TID:$92
Test result value: 0.36624V
PASS
MID:$06 TID:$93
Max: 8 Min: 0
Test result value: 1.25
PASS
MID:$21 TID:$a0
- Catalyst Monitor Bank 1
Max: 0.99939 Min: 0.3498
Test result value: 0.92067
PASS
MID:$22 TID:$a0
- Catalyst Monitor Bank 2
Test result value: 0.91927
PASS
MID:$3a TID:$c0
- EVAP Monitor (cap off)
Max: 14L Min: 0L
Test result value: 2.09L
PASS
MID:$3a TID:$c1
Test incomplete or dependant test failed
MID:$3c TID:$c8
- EVAP Monitor (0.040")
MID:$3c TID:$c9
Max: 0.72655Ratio Min: 0Ratio
Test result value: 0.07422Ratio
PASS
MID:$3c TID:$ca
Max: 1Count Min: 0Count
Test result value: 0Count
PASS
MID:$3c TID:$cb
PASS
MID:$3d TID:$c4
- EVAP Monitor (0.020")
Max: 6,553.5S Min: 60S
Test result value: 60S
PASS
MID:$3d TID:$c5
Max: 2,500Pa Min: -8,000Pa
Test result value: 328Pa
PASS
MID:$3d TID:$c6
Max: 60S Min: 0S
Test result value: 1.3S
PASS
MID:$3d TID:$c7
Max: 40L Min: 10L
Test result value: 10L
PASS
MID:$41 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 8Count Min: 0Count
PASS
MID:$41 TID:$d3
Max: 2.481 Min: -4.211
Test result value: -0.183
PASS
MID:$42 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 2
PASS
MID:$42 TID:$d3
Max: 2.481 Min: -4.199
Test result value: -0.412
PASS
MID:$45 TID:$d2
- O2 Heater Monitor Bank 2 - Sensor 1
PASS
MID:$45 TID:$d3
Test result value: -0.332
PASS
MID:$46 TID:$d2
- O2 Heater Monitor Bank 2 - Sensor 2
PASS
MID:$46 TID:$d3
Test result value: -0.029
PASS
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
MID:$a8 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data
PASS
MID:$a8 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data
PASS
MID:$a9 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data
PASS
MID:$a9 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data
PASS
End of report.
PASS
MID:$41 TID:$d3
PASS
MID:$42 TID:$d2
PASS
MID:$42 TID:$d3
PASS
MID:$45 TID:$d2
PASS
MID:$45 TID:$d3
PASS
MID:$46 TID:$d2
PASS
MID:$46 TID:$d3
PASS
MID:$a2 TID:$0b
PASS
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0b
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0b
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0b
PASS
MID:$a5 TID:$0c
PASS
MID:$a6 TID:$0b
PASS
MID:$a6 TID:$0c
PASS
MID:$a7 TID:$0b
PASS
MID:$a7 TID:$0c
PASS
MID:$a8 TID:$0b
PASS
MID:$a8 TID:$0c
PASS
MID:$a9 TID:$0b
PASS
MID:$a9 TID:$0c
PASS
End of report.
CrackerJackToy
12-01-2008 06:26 AM
davyo
27
02-16-2008 09:27 PM
HummBob
10-20-2007 03:06 PM
CarlosC
09-30-2007 08:46 PM
DrCarver
04-10-2007 10:34 AM
