Service four wheel drive
Have you checked to see if your 4whl drive system is working properly? Is your ABS light on too? I would try these things as well. but definitly get a code pulled. Odds are you will need a high end (tech 2) scanner to get the code.
If the ABS light is on you probably have a bad wheel speed sensor. Its an easy fix.
If the ABS light is not on im willing to bet you have a bad transfer case **** motor. Also an easy fix.
tbraly
04-19-2014 08:36 AM
Caraddict
10-09-2013 04:59 PM
bhsanchez72
01-26-2013 09:15 PM
NJTEX
11-10-2007 10:26 PM
alphafourwheeldrive
02-13-2007 07:33 PM
