How to replace cabin air filter - Hummer Forums - Enthusiast Forum for Hummer Owners
Reply
LinkBack Thread Tools Search this Thread
Old 11-18-2009, 07:59 PM
Default How to replace cabin air filter
Hi Guys, I just find out this video on how to replace cabin air filter. Its relatively simple repair that can be done in a few minutes. I just don't know if that will work for hummer? Any suggestions? Thanks.
Old 11-19-2009, 11:20 AM
If your Hummer has one it's inside the H2 on the lower portion of the right side dash. The filter sits verticle.
Old 11-23-2009, 05:10 AM
D VADER's Avatar
The H3 doesn't have a cabin filter.
Old 11-24-2009, 05:17 PM
2wheelmonster's Avatar
The only filter that the cabin might have is probalby in the fire wall where the blower motor gets air from
Old 12-02-2009, 01:17 AM
Replacing your car's air cabin filter is a relatively simple:
1. Remove the main access cover, undo the cover fasteners to remove cover and side cover if needed.
2. Locate and undo retainer clip to remove air cabin filter, compare the filter size to the replacement filter and reassemble.
Old 12-02-2009, 06:46 AM
D VADER's Avatar
You must be referring to the H2 as the H3 has no cabin filter.
Old 12-17-2009, 08:28 PM
I am a non-smoker. The filters were pretty clean at 30K miles. You could hold them up to the light and see quite well through them. In fact I've set them aside for possible re-use.
The climate in New England is not very dusty and there are few gravel roads. I was not having any problems with feeling the AC, either. The reason for erring on the side of preventive maintenance was concern over getting my allergies riled up.
A friend who has a Subaru shared a similar story about his cabin air filter.
Old 02-13-2010, 03:38 AM
Thanks to acai berry juice, after 41 years, I'm no longer a smoker!
Old 02-13-2010, 07:26 AM
D VADER's Avatar
Angry
Quote:
But you still SUCK!!
Reply
Thread Thread Starter Forum Replies Last Post
Installing a cabin air filter Stosh Hummer H2 38 10-27-2016 11:17 PM
Cabin air filter basic123 Hummer H1 1 11-24-2011 08:10 AM
Cabin air filter balzout Hummer H2 8 08-03-2011 05:39 PM
Cabin Air Filter Skoal Hummer H3 7 03-29-2007 12:48 PM
H3 Cabin Air Filter HummerGuy Hummer H3 11 10-19-2006 12:15 PM
Tags
2006, air, cabin, change, filter, fliter, forums, h2, h3, h3t, hummer, install, motor, oil, replacement, york
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
