Yellow Roof Lights?! How...Where...?
Hey guys!
I see all these H2's with roughly 4-5 small yellowish/orangeish lights on their roofs above the front windshield and it looks great especially when it's night.
I can't seem to find where I would buy these for my H3. Does anyone have any suggestions? I've attached a couple of photos so you know what I'm talking about.
Thanks guys!
Thanks guys!
Those running lights were a factory option. Mine has them.
They were also available as a dealer installed option.
They were also available as a self install kit.
They are no longer made. GM has no stock left. Your only hope is that an occasional set shows up on Ebay once in a while but they are $$$$$. Beware of buying used ones that have already been installed. They mount with Rivenut fasteners that stay behind on the vehicle it comes off of. You would need a set of those fasteners to be able to mount it to your vehicle and they aren't easy to find either. The fasteners also require a special tool to install the Rivenuts to the roof.
A clone is available from G-Style at $1200, but i haven't heard of anyone buying a set, so I have no clue on the quality of those
What Bunger said.
The other option is, you buy a set of individual aftermarket lights, installing each separately in a similar pattern (or make your own pattern) then wire them together and tap the running light/headlight circuit (or wire a separate switch) to power. There are some guys that have done this and made the results look pretty darn good.
This, but still missing the middle plastic housing.
2006 2010 Hummer H3 Roof Mounted CLEARANCE Lights Lamps Full Set 5X New | eBay
Still not following man. It looks like the eBay link you posted had all 5 lights, so I just don't know what's missing. Sorry mate!
