Wire for aux lights into cab
Best place would be found by a SEARCH: Hummer Forums - Enthusiast Forum for Hummer Owners - Search Results
Under the dash behind the steering column is a factory pass-through for the wiring harness from the engine compartment. The H3 has a double firewall so there are also two grommets there. You could also drill your own hole and install a grommet where ever you wanted. I think that there are one or two other pass-throughs as well.
look where the clutch pedal would be and find a hole in one layer of the two layers. its a good place to drill a 3/4- 1 inch hole with a unibit or hole punch as i did. run wire thru a grommet or rubber hose and fill voids with putty.
youll be ready for the NEXT wires!
Brent Whitfield
02-12-2014 06:40 PM
jasontag
04-26-2010 10:08 AM
mountainbiker
02-06-2007 05:44 AM
