Window Switch
Old 12-19-2014, 01:31 PM
rayfry08's Avatar
Default Window Switch
Anyone replace bulbs in the window switch? Pulled the switch apart and found only 2 bulbs. Sure I read somewhere on this forum that there were more but couldn't find them. What am I doing wrong?
Old 12-19-2014, 04:22 PM
wfturner's Avatar
If you are talking about the driver side window switch, then there are only two bulbs.
You can order additional bulbs here,
Five 5 Bulb for 2005 2010 Hummer H3 Heater A C Controls Window Switches Mini | eBay
Old 12-20-2014, 05:36 PM
Happy Hummer's Avatar
Yep. It is pretty straight forward if switch is already apart.
Chris
Old 12-22-2014, 09:28 AM
rayfry08's Avatar
Replaced the 2 bulbs in the window switch and it works fine. Wasn't that hard and sure saved a lot of money. Dealer wants you to purchase the whole window switch. Thanks to forum members for the info on the bulbs and how to remove the switch.
Old 12-25-2014, 06:28 PM
elmata's Avatar
Unhappy
Any reason the rear side window switch lights wouldn't come on after changing the bulbs? My front switch lights work but my rear switches wont light up, I replaced all the bulbs when I bought my 08 H3 last month. I did move the bulbs back up to the front to make sure they aren't bad and they light up but then when I move them back to the back two switches they won't light up. The switches will roll the windows up and down though.
Old 12-25-2014, 06:30 PM
elmata's Avatar
Forgot to mention they weren't lit up when I bought it that was one of the reasons I changed them. One was burned out the other works fine I kept the good one just for a spare.
Old 12-26-2014, 06:54 AM
rayfry08's Avatar
If the bulbs don't work, try turning them around 180 degrees. Someone on the forum suggested that and I tried it and it worked.
Old 12-28-2014, 10:31 AM
elmata's Avatar
Thanks ill have to try that and get back with yall.
hummerhack
12-17-2014 02:25 AM
WannaScoopaDis
02-07-2013 06:06 PM
VividVisions
04-27-2009 04:47 PM
ukpaul
01-05-2009 07:56 PM
heavyD
05-14-2008 04:52 PM
Quick Reply: Window Switch
