Water pump replacement -- help
In May -11 I had the radiator problem and got raked over the coals for $830. a few days ago, started smelling antifreeze... Dealer says it is a bad pump -now out of the 5yr/100,000 warranty 2wks ago. The fluid is leaking from the weep hole under pressure test. Cant afford the 650 price tag, but am a DIY'er.
Can anyone give DIY replacement assistance with torque specs?
Never had to replace a pump on an I5 before. Can't help ya there.
If you are just out of warranty by that little I would suggest contacting 1-800-HUMMER and see if they can do some sort of "good will" service for you. I have heard of them paying for the entire part and 1/2 of the labor.
torque specs
FRONT SUSPENSION
Hub and Bearing Assembly to Steering Knuckle Bolts 180 N·m 133 lb ft
Lower Control Arm Ball Joint Stud Nut
First Pass 85 N·m 63 lb ft
Second Pass Plus 60 degrees
Lower Control Arm to Frame Bolts Front 165 N·m 122 lb ft
Lower Control Arm to Frame Bolts Rear 180 N·m 133 lb ft
Shock Absorber Tenon Nut 30 N·m 22 lb ft
Shock Absorber to Lower Control Arm Nut 80 N·m 59 lb ft
Stabilizer Shaft Insulator Clamp Bolts 50 N·m 37 lb ft
Stabilizer Shaft Link Nuts 80 N·m 59 lb ft
Upper Control Arm Ball Pinch Bolt Nut 70 N·m 51 lb ft
Upper Control Arm to Frame Nuts 155 N·m 114 lb ft
Wheel Speed Sensor Mounting Bracket Bolt 20 N·m 15 lb ft
REAR SUSPENSION
Leaf Spring to Front Bracket Nut 125 N·m 92 lb ft
Leaf Spring U-Bolt Nuts 76 N·m 56 lb ft
Spring Shackle to Frame Nut 85 N·m 63 lb ft
Spring Shackle to Leaf Spring Nut 85 N·m 63 lb ft
Shock Absorber Lower Bolt 95 N·m 70 lb ft
Shock Absorber Upper Bolts 35 N·m 26 lb ft
Stabilizer Bar Lower Link Nut 80 N·m 59 lb ft
Stabilizer Bar Upper Link to Frame Nut 80 N·m 59 lb ft
Stabilizer Clamp Bolts 50 N·m 37 lb ft
WHEELS AND TIRES
Spare Wheel Carrier Nut 50 N·m 37 lb ft
Spare Wheel Carrier Assembly Double Ended Stud 20 N·m 15 lb ft
Spare Wheel Nut 125 N·m 92 lb ft
Wheel Lug Nut 140 N·m 103 lb ft
PROP SHAFTS
Bolt - Front Propeller Shaft CV Joint to Transfer Case Drive Flange (4) 70 N·m 51 lb ft
Bolt - Front Propeller Shaft to Front Pinion Yoke (4) 25 N·m 18 lb ft
Bolt - Rear Propeller Shaft Retainer (8) 25 N·m 18 lb ft
DRIVE SHAFT
Front Wheel Drive Shaft Nut 260 N·m 191 lb ft
FRONT DRIVE AXLE
Differential Carrier Assembly Bearing Cap Bolts 63 N·m 46 lb ft
Differential Carrier Assembly Mounting Bracket to Carrier Bolts 155 N·m 114 lb ft
Differential Carrier Assembly Mounting Bracket to Frame Bolts 155 N·m 114 lb ft
Differential Housing Cover Bolts 30 N·m 22 lb ft
Intermediate Shaft Housing Assembly to Axle Housing Bolts 67 N·m 49 lb ft
Intermediate Shaft Housing to Outer Housing Bolts 48 N·m 35 lb ft
Pinion Shaft Lock Screw/Bolt 25 N·m 18 lb ft
Plug, Drain and Fill 32 N·m 24 lb ft
Ring Gear Bolts 120 N·m 89 lb ft
Third Point Mount Bolt 110 N·m 81 lb ft
REAR DRIVE AXLE
Bearing Cap Bolt 75 N·m 55 lb ft
Brake Line Retainer Bolt 20 N·m 15 lb ft
Differential Housing Cover Bolt 25 N·m 18 lb ft
Disc Brake Backing Plate Bolt 135 N·m 100 lb ft
Fill/Drain Plug 33 N·m 24 lb ft
Park Brake Cable to Leaf Spring Bolt 20 N·m 18 lb ft
Pinion Shaft Lock Bolt 25 N·m 18 lb ft
Ring Gear Bolt 120 N·m 89 lb ft
Wheel Speed Sensor Bolt 18 N·m 138 lb ft
TRANSFER CASE
Adapter Studs 14 N·m 10 lb ft
Case Bolts 25 N·m 18 lb ft
Drain Plug 16 N·m 12 lb ft
Encoder Motor Bolts 10 N·m 89 lb in
Encoder Motor Bracket Bolt 10 N·m 89 lb in
Encoder Motor Support Bracket Nuts 5 N·m 44 lb in
Fill Plug 16 N·m 12 lb ft
Front Drive Shaft Universal Joint Clamp Bolts 20 N·m 15 lb ft
Front Output Shaft Flange Nut 319 N·m 235 lb ft
Transfer Case Shield Bolts 30 N·m 23 lb ft
Transfer Case to Transmission Nuts 50 N·m 37 lb ft
Transmission Crossmember to Frame Bracket - Horizontal - Bolts and Nuts 50 N·m 37 lb ft
Transmission Crossmember to Frame - Vertical - Bolts 100 N·m 74 lb ft
Transmission Mount to Support Nuts 57 N·m 42 lb ft
Vehicle Speed Sensor 17 N·m 13 lb ft
Vent 6 N·m 53 lb in
BUMPERS
Brush Guard Bolts - Lower Short Bolts 50 N·m 37 lb ft
Brush Guard Bolts - Upper Long Bolts 85 N·m 63 lb ft
Brush Guard Nuts 50 N·m 37 lb ft
Front Bumper Bolts 40 N·m 30 lb ft
Front Bumper Lower Bolts 50 N·m 37 lb ft
Front Bumper Upper Bolts 85 N·m 63 lb ft
Rear Bumper Bolts 32 N·m 24 lb ft
Rear Bumper Bracket to Bumper End Cap Nut 32 N·m 24 lb ft
Rear Bumper Bracket to Frame Bolts 85 N·m 63 lb ft
Rear Bumper Bracket to Trailer Hitch Nut 85 N·m 63 lb ft
Rear Bumper End Cap Nuts to Bumper 32 N·m 24 lb ft
Trailer Hitch Electrical Receptacle to Rear Bumper Bolts 32 N·m 24 lb ft
Trailer Hitch to Frame Bolts 100 N·m 74 lb ft
FRAME AND UNDERCARRIAGE
Assist Step Bolt 50 N·m 37 lb ft
Crossmember Bolt 160 N·m 118 lb ft
Engine Shield Bolt 20 N·m 15 lb ft
Frame Cushion/Insulator Bolt 115 N·m 85 lb ft
Front Differential Assembly Bolt 100 N·m 74 lb ft
Oil Pan Skid Plate Bolt 20 N·m 15 lb ft
Tow Hook Bracket to Front Frame Rail Bolt 85 N·m 63 lb ft
Tow Hook Bracket to Rear Frame Rail Bolt 100 N·m 74 lb ft
Tow Hook D Ring Nut
First Pass 50 N·m 37 lb ft
Second Pass Minus Approximately 180 degrees
Trailer Hitch to Frame (Horizontal) Bolt 160 N·m 118 lb ft
Trailer Hitch to Frame (Vertical) Bolt 100 N·m 74 lb ft
Transmission Mount to Support Nut 57 N·m 42 lb ft
Transmission Crossmember to Frame (Vertical) Bolt 100 N·m 74 lb ft
Transmission Crossmember to Frame Bracket (Horizontal) Nut 50 N·m 37 lb ft
Here's all of them. save link Welcome to Hummer Answers
The following were from TAINTER... BTW - Thanks alot.
Water Outlet Bolt 10 N.m 89 lb in
Water Pump Bolt 10 N.m 89 lb in
Water Pump Pulley Bolt 25 N.m 18 lb ft
REAR SUSPENSION
WHEELS AND TIRES
PROP SHAFTS
DRIVE SHAFT
FRONT DRIVE AXLE
REAR DRIVE AXLE
TRANSFER CASE
Vent 6 N·m 53 lb in
BUMPERS
Tow Hook D Ring Nut
Pump being replaced
On Friday, I contacted GM-Hummer and explained the situation. Today they called and I only have to pay a $150 deductible with a warranty on the fix. Will be done Thursday.
Thanks for all the help...
R1guy777
17
12-28-2013 09:29 PM
