Transmission Cooling Lines Help!!!!!
All, while replacing the radiator in my '07 H3, I broke off the transmission cooler line where it attaches to the radiator...right where the flared end enters the radiator. Is there any way to fix this without replacing the whole line? The line goes all the way back to the top of the trans and it looks impossible to reach. Is there a way of splicing into the rubber hose near where the line attaches to the radiator? How could I connect the splice to the radiator since the fitting on the radiator takes a flared end? Please help! Thanks!
Those lines look pretty corroded. you may need to replace the complete line. I would think any tranny shop can handle it.
I agree with whylee, those lines are very rotted and should be replaced. If your looking for something to get you by, you can run an aftermarket cooler and cut the lines further back(right behind the rubber lines).
I agree, replace them before they leave you stranded somewhere.
Since yours are down right ugly, and a brand new ACDelco line, depending upon which one you broke, is either $18 for #1 or $18 for #5, if I were you, I would replace both.
Hummer H3 Alpha
I know this is a thread from 2015, but it has some pics I need to use. Which of the lines on the transmission is connected to the transmission fluid pump? Does the pump push or suck?
Does the transmission pump fluid to the cooler or does it suck fluid like an engine's coolant pump? I have an aftermarket transmission cooler which is currently mounted vertically (both in and out lines are on the same elevation), but I may need to mount it horizontally (one line on top and the other line on the bottom).
If the transmission pump sucks, which of the two connections on the transmission is the suction line? If the transmission is a sucker, then I will need to connect the transmission's suction line to the bottom cooler fitting. Not sure which way to connect the lines if the transmission pump is a pusher.
Try a search for your inquiry. You are asking what is the trans line flow direction, google it and you get........... Transmission Cooler Lines Flow Direction
jayhawk714
04-03-2014 08:29 PM
