TPMS Removal Question - Hummer Forums - Enthusiast Forum for Hummer Owners
Reply
LinkBack Thread Tools Search this Thread
Old 01-05-2012, 07:41 PM
Default TPMS Removal Question
If I remove the sensors will I just get the SERV TPM message and not the the light with the low tire picture? or will the low tire light come be on?
Does the spare sensor do anything?
Old 01-05-2012, 08:04 PM
Mr. Fancy Pants's Avatar
You with get both but can clear the SERV TPM from the DIC by pushing the stick. However, the light will remain on.
The spare sensor in your spare do yo mean?
Old 01-05-2012, 09:25 PM
Does the system monitor the spare. I am thinking about not using one in the spare. I also will not rotate the spare in. I think I will keep the tire nice looking.
Old 01-06-2012, 12:07 PM
The system can only monitor 4 sensors at a time, so no the spare is not monitored.
Old 01-06-2012, 02:55 PM
08xcab's Avatar
I am running without sensors. The light is NOT on, but every month or so, I get the "svc tpm" error on the display. I just puch the stick and its gone for another month or 2.
Old 01-06-2012, 04:27 PM
It does monitor the spare depending on year. My '08 comes without one in the spare. My '07 had the spare set off the monitor once. Drove me nuts 'cause my tire pressure was fine until I was told to check the spare.
Old 01-06-2012, 04:35 PM
Quote:
They stopped putting sensors in the spares on mid 2007's but with that being said, the spares are not monitored unless programmed in. Meaning that if the computer is reading the spare, then there is one on the ground not being monitored because the system only monitors four sensors at one time.
Reply
Thread Thread Starter Forum Replies Last Post
Another TPMS question! mmaskilz New Member Area 0 08-29-2011 12:26 PM
New tires and tpms LesC. Tire and Wheel 1 12-23-2007 09:11 PM
TPMS and cold temps RealJeep Hummer H3 7 12-16-2007 11:44 AM
TPMS...HATE IT Bennersj Hummer H3 18 10-01-2007 06:18 AM
Do all H3's have TPMS? tarheel_34 Hummer H3 2 04-05-2007 12:51 AM
Tags
06, clearing, eliminate, h3, hummer, monitor, monitors, pressure, remove, resetting, sensors, spare, svc, tire, tpm, tpms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
