Thermostat stuck open
Over time the additives in the coolant deplete. Any time you have fluid moving through dissimilar metals there is a chance it can obtain a charge. The term is called electrolysis. The electrolysis can actually pit the metal in the coolant system. There is not a set "standard" that I know of, some say anything over .20 volts is bad, others say higher. Google coolant system electrolysis, and maybe something will pop up. I was only trying to give the original poster another avenue to look at, while he has attempting to find the cause of his DIC light. Sometimes you just have to throw the book out and learn from the guys with the dirty hands.
OMG that sux, I just had fluid changed. What is the wheel house, how long will ya think it will take. Do you have a guide?
sometime i believe what i read,,,then later i check the book.
compared to cars we worked on in the past,changing the thermo on th h3 is just short of a nightmare!!
yes you drain the system!.
no its not on top!
yes you pull the wheel house .
the thermo is below , rear of the starter, lower hose.
oh my i hope i never need to do it,,when its 5 degrees out!!
and btw the book says nothing about measuring the coolant "voltage"!
no its not on top!
checked the book agin
the successful mechanic usually has all the books he can get,,with dirty fingerprints throughout!! so have fun boys but if u want something fixed right look to someone who never makes stuff up to sound impressive...
like he said"No need to drain the coolant. You might spill a little on the ground but it wont be much. Pull upper radiator hose (should be on the water pump) and pull out the thermostat, put new one in and replace hose. "
arent thermostats always in the hose!!!
actually the upper hose goes to the block nowhere near the water pump
find the thermo as i told u from the "guide" and when you unhook the lower hose u will dump the fluid.
you might just want to take it in and keep your hands clean!! and warm
oh?,the wheelhouse,,just a term the gm engineers use . its where the wheel lives!!,like a dog house,,or cat house!!
Tom, in one of my first post, I stated I had never changed one in the Hummer. I was simply going off of previous experience with different engines. The I5 in a Hummer is obviously a different beast, and has its own idiosyncrasies. Electrolysis is a fact, and has been know to throw codes in GM vehicles. This horse has been beaten enough, and everyone (including myself) has hopefully learned something.
nncanfarelli
08-04-2019 09:27 PM
HumRluvR
05-31-2016 07:53 AM
johnmully
09-14-2013 11:51 AM
accely
09-05-2013 07:25 AM
Desert Dan
04-16-2008 08:19 AM
