Is there any chips for 06 h3
Throttle body spacers are complete garbage and do NOTHING, except drain your wallet. They can be effectively used as a paper weight.
Yes, but do not get me going on "cold air" as it is a misnomer of many sorts and ridiculously so for certain brands of OPEN intakes... nothin but a "warm air intake" if you get my drift .....
Anyways, I have one of our Air Doc Intakes in front of my PP TB from Super Modulation.
The full package.... AFE Pro Dry S filter with Air Doc Intake, PP TB, PCMofNC Efan Conversion and PCM Tune, with MagnaFlow Cat back.
The Air Doc Intake retains the factory air filter box, so you use any filter that is a direct replacement for the factory air filter. It is a "Closed" system.
That cone filter on the end of a pipe behind the radiator in the corner set up is an "open" system that is self defeating... it can potentially move more air, but warmer heated air, thus offsetting it's own potential gain.
With your 2006, the Air Doc has a larger more efficient inlet snorkel for the Air Filter Box from the inner fender that replaces the stock small diameter air box snorkel.
If I were you, I would install the PCM first, make sure it is all set with no other issue. I am not suggesting you drive it around for a week, just make sure that your truck starts and idles correctly. Then install the TB and Air Doc when you have the OEM intake off. Follow the instructions regarding the TB.... it does not care if an intake is in front of it while the PCM adjusts/calibrates to the TB Throttle Position Sensor for idle. You should also note that for the first several weeks when you first start the truck, wait 10-20 seconds for it to idle before placing it in gear. As the PCM learns the package, that will fade away.
Then drive and enjoy.
Thumper
06-23-2010 05:42 PM
Wu Jen
02-19-2007 12:55 AM
amstaffbair
17
01-11-2007 06:41 PM
nuck
09-21-2005 09:27 PM
