Tail Lights
Yes. I would start by checking the fuses. If they are all fine, get a test light and check the socket for power. If you have no power then check the connection at the socket on the back side of the housing. This connection might have came loose when you changed the bulb because those connections are strong but not indestructable. Or it could have easily came loose especially over the years of driving. Chances are the wires the rest of the way are fine. Try that! and see if that helps.
this exact same thing just happened to me... so what's the solution to this issue?
I have done a search and many people have had this issue, but there isn't really any real solution just yet... Please share your experience...
thanx in advance!
richie
thanx in advance!
richie
LasseS
16
10-24-2012 06:30 AM
H8MYX
12-09-2006 06:40 PM
HummBob
10-06-2006 01:04 PM
