T-Case stuck in 4 wheel low
Old 10-05-2007, 09:24 PM
funkDoc's Avatar
Default T-Case stuck in 4 wheel low
Hey All,
I'm new to thses forums and I have 06 H3. I did some searching but couldn't find anything regarding this.
I did some wheeling today and engaged 4 low, and now it wont shift out of 4 low. I have used 4 low in the past and had no problems going back to 4 high. I have tried everything and it simply wont shift out of 4 low. The light never blinks when I push the button. I spent arounf 45 min trying everything with no success.
The car is stuck in vail at the moment so any advice you have would be greatly appreciated.
Old 10-05-2007, 10:02 PM
Default RE: T-Case stuck in 4 wheel low
did you try going in reverse about 5-10 mph while turning left and right...this should kick her out of 4-low. If not, try going under and unplugging the plugs on the t-case.....clean em out then plug it back in. This connector has given people problems in the past.
Old 10-05-2007, 11:02 PM
funkDoc's Avatar
That's good advice. One thing is that there is no feedback if I push the buttons. They never blink or anything when I push them. I'll do what you mentioned because I did go through some water and mud after going into 4 low. Thanks again.
Old 10-06-2007, 12:00 AM
hilljob26's Avatar
it may be the switch,i know i had a similer problem on my truck
Old 10-06-2007, 07:30 PM
Muddydawg75's Avatar
So... did that fix it?
Old 10-06-2007, 08:19 PM
SteveO's Avatar
I know this may be the obvious but I will ask anyway. Are you putting it in neutral before putting it in low lock?? It needs to be in neutral.
Old 10-06-2007, 09:00 PM
h3carlos's Avatar
So...did it work?
Old 10-07-2007, 10:03 AM
I vote TCase plug fart, might have got gerdoo in the connection, or loose. The switches can go as well? Any luck funkDoc?? ?????
Old 10-07-2007, 04:42 PM
hilljob26's Avatar
when i switched switches,it fixed it,but not sure in your case
Old 10-10-2007, 07:25 AM
also, make sure the button isn't stuck. It happend to me that way...i must have pushed the button sideways a little, and it got stuck. I felt like an asshat when i figured it out...lol
Quick Reply: T-Case stuck in 4 wheel low
