Switched Ignition help
I am going to be hooking up my trans oil cooler Fan to a switched ignition source. I have ordered a "add a circuit" where I will use one of the fuses. Which fuse would be best to use for switched ignition? Any help would be greatly appreciated.
I assume the "add a fuse" is what I would call a fuse buddy? Plugs into fuse location and has 2 fuses in it to create another circuit? If so buy a 4 pin relay and wire the extra circuit from the add a fuse to pin 86 on relay. Pin 85 needs a ground. Pin 30 to battery positive. Pin 87 to fan positive wire. Then add ground circuit to chassis ground from fan. Do all that with battery disconnected to be safe.
