Sunroof is Stuck Open in Vent Position???
Old 04-15-2008, 09:52 AM
Desert Dan's Avatar
Default Sunroof is Stuck Open in Vent Position???
Any advice on what would be wrong? My Sunroof is Stuck Open in Vent Position.
I checked both fuses assoicated with the sunroof and dissconnected the battery for about a minute hoping that would reset set any gremlins.
When you push the switch for the sunroof you don't hear the motor moving etc.
Thanks for any advice you have before I take it to the dealer
Old 04-15-2008, 12:03 PM
Default RE: Sunroof is Stuck Open in Vent Position???
[sm=signs006.gif]Haven't seen or heard that one.
Old 04-15-2008, 12:24 PM
CWS's Avatar
CWS
CWS is offline
Sounds like a bum switch to me.
Cliff
Old 04-15-2008, 06:20 PM
Desert Dan's Avatar
I tried holding down the switch for 30 seconds todayand I heard the sunroof motor move a little.
I'll try cleaning the tracks and rollers and lubricating them with WD-40 and or silicone spray and see it help get the sunroof moving again.
Old 04-15-2008, 07:03 PM
Hummer Guy's Avatar
would be the wiring or one of the components - it's relatively in depth to diagnose - I'd let the dealer work on it.
Old 04-16-2008, 08:19 AM
Maybe have someone "gently" push down on the sunroof while you work the switch. It might get it down until you can get it to the dealer.
nncanfarelli
08-04-2019 09:27 PM
HumRluvR
05-31-2016 07:53 AM
accely
09-05-2013 07:25 AM
bigdog100
12-15-2010 12:45 PM
John Taddeo
03-23-2009 08:51 AM
Quick Reply: Sunroof is Stuck Open in Vent Position???
