Shadow Green Metallic H3 Build Thread
Old 01-24-2017, 12:36 PM
Jayson DK's Avatar
More updates -
Sick of the chrome finish on the shifter bezel and radio face plate. Radio face plate was easy enough to sand down and tape off... of course the shifter bezel isnt removable from the top of the console. Sanded surfaces down, sprayed them stainless steel. Came out great. I also have unmolested factory pieces available.
The subwoofer and amp mounting looks awesome. I may cut out the plastic and throw a piece of plexiglass behind there. Sucks to have to cover it up.
Changed out the radio... again. This time (third) I got a Joying 2gb 5.1.1 unit. It works, and sounds great. Added the bass boost remote too.
Ordered color match spare tire cover. Last picture is a sneak peak while I wait for the 1" body lift, and tail light tint. Also got kicker battery terminal replacements with 0GA inputs, and a new hood release cable.
  #22
Old 01-25-2017, 02:36 PM
74stinger's Avatar
Great build! Thanks for the updates.
  #23
Old 01-31-2017, 10:48 AM
Jayson DK's Avatar
Decided to paint the shifter bezel... bought a whole new top console piece. Matches the new painted stainless radio faceplate perfectly.
Also finally got all the gay chrome tinted. Tail lights & side markers... look awesome now.
Put on color matched spare tire cover.
Also I have ALL my old parts for sale... see below
FOR SALE:
Factory Polished Center Console / Shifter Bezel:
2006-2010 HUMMER H3 CENTER CONSOLE UPPER SECTION TRIM CUP Holder Shifter Bezel | eBay
Factory Polished Radio bezel (w one small scratch):
2006-2010 HUMMER H3 OEM RADIO TRIM BEZEL FACE PLATE ALUMINUM CHROME A/C VENTS | eBay
Factory transfer case module:
2006-2010 Hummer H3 OEM Transfer Case Module w/ Rear Locking Diff 24236867
Factory OEM Monsoon amplifier:
2006-2010 HUMMER H3 OEM RADIO STEREO AUDIO AMP AMPLIFIER MONSOON SYSTEM 15086821
Factory monsoon rear door speakers:
2x 2006-2010 HUMMER H3 OEM REAR DOOR SPEAKERS 15086827 DELCO TESTED | eBay
Factory Radio:
2006-2010 Gm Hummer H3 H3T OEM Chrome 6 Disc Cd Changer Am/Fm Radio 15261537 | eBay
Factory Monsoon tweeters:
2x 2006-2010 HUMMER H3 OEM Front A-Pillar Tweeters Monsoon TESTED | eBay
Factory OEM heater/ac controls (slight damage to middle button)
2006-2010 HUMMER H3 OEM Heater Temperature A/C Climate Control Contoller Fan | eBay
Factory OEM heater a/c controls with no damage:
Factory programmed speedometer:
06-10 HUMMER H3 INSTRUMENT GAUGE CLUSTER SPEEDOMETER PROGRAMMED TO YOUR MILEAGE | eBay
Factory transfer case 4x4 switch:
2006-2010 HUMMER H3 OEM TRANSFER CASE TRACTION 4X4 CONTROL SWITCH Front Dash | eBay
Factory OEM front side markers:
2006-2010 HUMMER H3 OEM LH&RH SIDE MARKER LIGHTS LAMPS orange Front Fender
NEW aftermarket amber turn signals:
2x 2006-2010 NEW Hummer H3 LH & RH Front Turn Signal Lamps Amber Sealed In Box | eBay
OEM Foggy fog lights:
2006-2010 Hummer H3 Fog Lights OEM LH & RH Foggy | eBay
OEM LH Headlight:
2006-2010 HUMMER H3 FRONT LEFT HEAD LIGHT HEADLIGHT W/ TURN LAMP ASSEMBLY OEM | eBay
OEM RH Headlight:
2006-2010 HUMMER H3 FRONT RIGHT HEAD LIGHT HEADLIGHT W/ TURN LAMP ASSEMBLY OEM | eBay
OEM 16" Wheels w/ excellent condition 33" Bridgestone all terrain tires:
06-10 Hummer H3 4x OEM 16x8.5" Wheels & 33" Bridgestone All Terrain A/T Tires | eBay
  #24
Old 02-02-2017, 09:17 AM
TeeJay's Avatar
huge inspo for me to follow thru with the idea of a hummer vs an FJ80. Thanks!
  #25
Old 02-04-2017, 03:12 PM
Jayson DK's Avatar
Old 02-05-2017, 08:57 AM
74stinger's Avatar
What do you do to keep the black plastic trim dark & black? Are they painted? Looks great!
  #27
Old 02-05-2017, 09:16 AM
Wow, all that time, outstanding effort and $ spent and no change to the spare tire to mimic the height of the new RIMz and tires. One of the biggest tell tale signs when looking at a rig if it is used OffRoad like it was intended.
  #28
Old 02-05-2017, 09:55 AM
Jayson DK's Avatar
The gray plastic around the bottom of the truck is painted. The upper plastic trims were wipe new-ed.
This is actually a budget build for me for a few month winter vehicle. I got the tires slightly used at a great price. Diddnt make logical sense to spend the extra $600+ on another spare wheel and new tire.
  #29
Old 02-05-2017, 01:54 PM
35.3" and a 32.8" spare would not be drive train/computer friendly in case of a flat. Maybe a few miles that's it.
You could pick up a used 315/75r16 for your existing 16" spare wheel. Most are around 34.7" tall. A lot closer to your 35.3".
I do hope you have tow coverage on your insurance, just in case of a flat.
As stated you before, glad to see someone taking the time and effort to save a green 06. Favorite color on a HUMMER.
  #30
Old 02-05-2017, 02:00 PM
Jayson DK's Avatar
The spare is just there for looks. Anything bigger than the 33" I have on there now wouldn't fit the cover.
I have 12x 100 mile tows a year with AAA, my own trailer and truck, and my best friend owns a tow company.
Thanks for the advice though
Quick Reply: Shadow Green Metallic H3 Build Thread
