Replace Fuse Block
Old 10-05-2015, 08:27 PM
JerseyJoe's Avatar
Default Replace Fuse Block
My intermittant and low speed wipers have stopped working, now they only work on high. I have read some threads on potential causes. Took it to the dealer, they found a short to the battery in the fuse block (code b3718). The solution is to replace the fuse block. Cost $708. I haven't seen any threads or youtube videos on replacing the fuse block. How hard is this to replace and how much "should" it cost. Thanks.
I have a 2008 H3 I5, 134k miles
Old 10-12-2015, 11:14 AM
The fuse block is almost a snap in place replacement, should take 10 minutes. You can buy the fuse box fuse block on Ebay loaded with all the fuses for about $150.
Here is an old thread that talks about getting to the alternator from the top (ie move the fuse box out of the way). https://www.hummerforums.com/forum/h...ictures-23158/
Here is a fuse block on Ebay: 2009 10 Genuine Hummer H3 5 3L Loaded Fuse Box Block 25783695 | eBay
Old 10-12-2015, 12:11 PM
happythree's Avatar
if it was caused by someone,,plugging it in wrong,twisterd, a good electrical guy might find it.
it could happen to the new one...
i never pulled mine and dont want to!!
its worth a look.
Old 10-18-2015, 08:42 PM
JerseyJoe's Avatar
Default Fuse Box
Thanks Doc. The link has some good pics. My H3 is 2008. The fuse box on ebay is for 2009. Is it the same part for both years? Joe
Old 11-08-2015, 05:39 PM
JerseyJoe's Avatar
Doc, will the 2009 fuse block fit in my 2008 H3? Is it the same?
paultimmins
10-11-2011 09:30 AM
gio
09-30-2007 09:18 AM
Pendar
21
02-05-2007 04:58 PM
HummerBlues
09-27-2006 05:42 PM
skeeet
09-04-2006 12:34 AM
Quick Reply: Replace Fuse Block
