Service 4WD Light
Old 07-29-2012, 09:45 PM
VictoryRed07's Avatar
Default Service 4WD Light
Hey all I'm new to the forums and to the H3s. I just bought it 2 weeks ago. Today I installed a rearview camera in it and once i reconnected the battery i now have a Service 4WD message on the dash. It was not on before the install. is this something i should be concerned about and what can i do to fix the issue without returning to the dealer?
Old 07-30-2012, 04:04 AM
dafihummer's Avatar
quickest try is to disconnect and reconnect the battery.. if it doesnt help, you might have an issue...long discussed here, if you do a search
Old 07-30-2012, 09:08 AM
2wheelmonster's Avatar
definitely try dis-connecting it again and waiting a few minutes
Old 07-30-2012, 02:09 PM
Thanks for the suggestions. I had planned on doing that tonight as well as checking the connections on the center panel above the radio. I did a search but couldn't find anything that seemed to help me.
Old 07-30-2012, 04:05 PM
Check the 4wd buttons, they tend to stick, make sure they are all out.
Old 07-30-2012, 06:05 PM
skeeter's Avatar
I know I had that problem changed the fluid and everything was good
Old 07-30-2012, 07:05 PM
RickStang's Avatar
disconnect/reconnect all the connections on your center console. I had the same problem when I installed my dvd player. Good luck
Old 07-30-2012, 07:26 PM
Seriously, make sure the buttons are all in the same outward position.. If 1 gets stuck, it sends conflicting signals to the computer=Service 4WD.... tap on all of them and make sure they all pop out to the same outward level position. if 1 seems inward, pull it out. Shut vehicle off & restart. No reason to go to the fluid, since you did nothing to the fluid to cause the light, & Battery disconnect has nothing to do with it. GL
Old 07-30-2012, 08:34 PM
Thanks for all the suggestions but the problem was that the connector behind the center panel had popped out. I must not have got it snapped in enough. Problem solved!
Old 07-30-2012, 08:53 PM
Glad you got it corrected. Future reference: tech101 push, listen for "click", if you are unsure, lightly pull on connector, if it stays in, then it is connected, (even though I know, I still give it another push, just to make sure). I also make sure to count the connectors taken apart, and remember that count when reinstalling.
ReadyGun
12-09-2013 03:23 PM
njbrat413
08-01-2013 07:37 AM
dafihummer
10-26-2011 09:13 AM
07superbee
12-20-2007 08:47 PM
Quick Reply: Service 4WD Light
