Roof Rack Build
Roof Rack Build
So i was thinking of what accessory i wanted next, and a roof rack is what i really wanted. So i started looking for one and found the Gobi was something that i really liked..........But the price was crazy high....for me.
So i thought i should make one.
Here is my build
Hummer Forums - Enthusiast Forum for Hummer Owners - Zero83's Album: Roof Rack
Here is my build
so what i did was added some tabs for my bolts on the rack that came straight down, (you can kinda see them in the pic of the rack hanging after paint)
but the mount is a bolt head that fits in the channel with a washer attached to the bolt head. that keeps the bolt in the channel and not spinning.
the raiser that spaces the rack off the top has a washer attached to the inside so i can bolt it together. once the spacers were tightly bolted to the channel, the rack just sat inside and bolted to the spacers.
i added a few more pics, i hope that helps.
So is it fabbed up in steel or aluminum? Also, how likely would you consider posting up a stock supply list, dimensions, and or a sketch. While i am somewhat mechanically inclined i have never welded. This would give me a reason to add a rig to my garage and start playing. I cant really see a ton of complexity outside of 22.5 degree angles, and patience. How many hours would you say that you have invested?
yes same idea. but my rack is wide. so i put something like that inside the spacer.
the only deference is i welded a washer inside the spacer so i could bolt the spacer to the channel on the truck.
and the outside measurements are 50"wide by 84" long.
but as far as supply list... most i already had in this shop from other projects.
i did however have to buy a 4'x8' sheet of expanded metal for the floor.
id say all in all total price would be somewhere around $250 or so.
ddupreyjr
02-06-2015 07:01 AM
DennyOK
10-31-2012 11:01 AM
Caraddict
04-22-2011 07:13 AM
FloridaFeMan
20
02-18-2010 08:19 AM
