roof leaks...
Old 01-22-2011, 02:29 PM
skyymaster's Avatar
Default roof leaks...
I was wondering if anyone has had problems with the running lights allowing water to enter into the roof area when it rains. I have tried several things to solve this problem and am wondering what it does take to stop the leakage.
Old 01-23-2011, 08:00 AM
Usually cleaning the sunroof drains & lines as well as making sure that the clearance lamps are sealed properly. Usually the lamps get loose and the seal no longer seals, allowing water in.. Jamie
Old 01-26-2011, 05:13 PM
luda81's Avatar
I had leaks that was caused by the roof lights but were is the sun roof drain holes??? I want to clean them even though i don't have any leaks.
Old 01-27-2011, 07:13 AM
If yours is equipped with them They are in the sunroof track assembly and hidden behind the head liner and body pillars. I would make sure your track is clean and that you have no debris in there to possibly block or bind anything.
alexismya
12-24-2011 07:35 PM
BoneChief13
08-07-2011 07:09 PM
jolibee30
08-18-2010 05:35 PM
nicos
02-24-2008 09:07 AM
syphon
01-13-2008 12:15 PM
Quick Reply: roof leaks...
