Remove front turn signal plastic cover - Hummer Forums - Enthusiast Forum for Hummer Owners
Reply
Thread Tools Search this Thread
Old 04-25-2010, 10:26 AM
Default Remove front turn signal plastic cover
Need to replace front turn signal bulb. took off front bumper, but I am having difficutlty getting the yellow plastic cover off the front to access the bulb. It has fout plastic clips on each sides as part of the cover, but when I lift these the plastic cover will not release. I've tried to gently, with increasing force, to pry the covers off but it is going to take a lot of force which may break it. I guess this is the General's way of keeping Mr. Goodwrench employed. Any suggestions?
Old 04-25-2010, 01:01 PM
RKSmith163's Avatar
Quote:
I think the bulb is a twist lock accessed from the back by removing the inner fender liner. I am not sure. I did all LED's a couple of years ago so I don't exacty remember. Do a search on this forum and you should find the answer for sure.
Old 06-04-2010, 06:31 PM
Have to access it from the wheel well. All it is is about 4-5 plastic rivets and a 4-5 10mm bolts and its off. Should be self explanatory from there, but its been awhile so I could be wrong.
Old 06-04-2010, 06:44 PM
2wheelmonster's Avatar
I believe it's a twist and pull out bulb from the behind it
Reply
Thread Thread Starter Forum Replies Last Post
How to remove H3 front turn signal housing? DanRay83 Hummer H3 21 12-02-2014 03:57 PM
Hummer H3 stock amber front turn signal lights groomsxxx PRIVATE For Sale / Trade Classifieds 1 04-11-2013 08:19 PM
Buld # front turn signal vernrose Hummer H3 5 04-25-2010 08:54 AM
How to remove and install turn signal-parking lights on Hummer H3 Agente General Hummer Talk 0 07-07-2009 12:05 AM
Clear front turn signal lights, 07 H3 hotrod PRIVATE For Sale / Trade Classifieds 0 02-17-2009 05:40 PM
Tags
2008, bulb, bumper, change, cover, front, h1, h3, hummer, install, led, plastic, removing, replace, signal, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
