remove front grille H3 2006
Old 08-09-2011, 02:28 PM
joostie62's Avatar
Default remove front grille H3 2006
Hi,
i am trying to remove the front chrome chrill in front of the radiator.
I have undone the screws but there is a small white plastic clip on both sides.
how do i get these off or release them in order to remove the grill.
thanks guys,
joost
Old 08-09-2011, 02:52 PM
wfturner's Avatar
Pull straight forward
should be two clips per side
Old 08-09-2011, 07:02 PM
joostie62's Avatar
OK got it... nothing broke or damaged...
thanks
Old 08-11-2011, 05:24 AM
2wheelmonster's Avatar
dealing with clips can be a bitch
Old 03-26-2012, 12:36 PM
xca2a1's Avatar
Default Need help removing front grill on '09 H3T
I removed the two nuts from inside and popped the end clips loose but there are still 3 fasteners, on inside each of the grill ribs. I don't want to force them and break something. Does anyone have a suggestion on how to removed these? Thanks!
Old 03-26-2012, 12:42 PM
Broken Halo's Avatar
Besides the 2 nuts you found on the inside, there's also 2 screws on the inside, as well as 2 screws on the outside between the grille slots. Total: 6 fasteners and 4 clips.
To remove the 2 screws on the outside between the grille slots you'll need a socket extension and a 10mm socket.
Old 03-28-2012, 11:42 AM
xca2a1's Avatar
Default Front Grill
Worked great, thanks!
Old 03-28-2012, 12:38 PM
wfturner's Avatar
Keep an eye on those small white plastic clips
They break rather easily, then they wont hold
jeffwhiteis
07-19-2010 01:28 PM
theBroken
02-22-2010 01:28 AM
Cali Man
06-05-2007 05:20 PM
AudialExcursions
03-13-2007 01:31 AM
timtran
07-18-2006 10:28 PM
Quick Reply: remove front grille H3 2006
