Rearview Mirror - Temperature Display Problem
Old 08-24-2010, 06:45 PM
thermalfrost's Avatar
Default Rearview Mirror - Temperature Display Problem
Temperature and direction (N, S, E, W) display has stopped working (just blank - nothing showing) in rearview mirror. Onstar controls working OK. Anyone else had this probem or know of some "reset" feature for a quick fix? Vehicle is still under warranty so dealer should be able to fix things, but thought I'd check here first for any suggestions.
Old 08-24-2010, 07:58 PM
DJINCO's Avatar
Go to a cul-de-sac or parking lot and drive in a tight circle a couple of revolutions. Drive in opposite direction (circle left, circle right).
That should calibrate the compass.
Cheers, Doug
Old 08-24-2010, 08:41 PM
RKSmith163's Avatar
Check and make sure you didn't power it off. It should be the far left button.
Old 08-24-2010, 09:11 PM
Autobot85's Avatar
Try disconnecting the wiring harness out of the back of the mirror for a minute, and then reconnect. good luck
Old 08-25-2010, 07:08 PM
Thanks to all. Got it going again.
Old 08-25-2010, 07:56 PM
Mr. Fancy Pants's Avatar
what did you do? it might help someone later on.
Old 08-25-2010, 08:53 PM
85_305's Avatar
Banned
Ya what did you do? Push and hold the "power" button on the mirror?
Intercooled
11-20-2013 09:25 AM
H32006
03-06-2012 05:03 PM
No more Jeeps
01-11-2011 05:34 PM
TravelMan
07-30-2009 04:38 PM
ronnie4946
11-11-2008 10:34 AM
Quick Reply: Rearview Mirror - Temperature Display Problem
