Real Hood Louvers Expelling Engine Heat ?
Today looking at the fake hood louver on my H3 and wondered if it's worth buying the real deal at HoodLouvers.com. I can see this concept working pulling hot air out of the engine bay but it's not cheap at $350 + shipping. I thought about cutting the hood myself and doing a DIY fabbed job but I'm not that handy nor can I wrench where I live - HOA rules. Anyone care to offer an opinion? Is it worth the hassle and expense? Thanks in advance!
Hummers - Hood Louvers | RunCool | Hood Vents For Your Vehicle -Hood Louvers | RunCool | Hood Vents For Your Vehicle -
Hummer H3 Testimonials - Hood Louvers | RunCool | Hood Vents For Your Vehicle -Hood Louvers | RunCool | Hood Vents For Your Vehicle -
No, the mod is not a magic pill for solving overheating issues. It does work, but not as much as I had wanted it to. If you like the looks or like to tinker and make stuff then its worth it. But if asking MY opinion, YOU will not be happy with the price/effort/results tradeoffs. Me? I would do it to my own again because its uniquely mine.
Yes it does let alot of heat escape, how much I am not sure, but on these vehicles anything is better than nothing. I noticed a big improvement in heat soaking after shut off.
When I park and shut off the engine, I can feel the heat rising out through the vents instead of just sitting under the hood heat soaking everything.
I cant say there is any benefit, but I can not see how less heat soak is a bad thing for the motor and electrical components.
Yes it does let alot of heat escape, how much I am not sure, but on these vehicles anything is better than nothing. I noticed a big improvement in heat soaking after shut off. When I park and shut off the engine, I can feel the heat rising out through the vents instead of just sitting under the hood heat soaking everything. I cant say there is any benefit, but I can not see how less heat soak is a bad thing for the motor and electrical components.
Thanks!
I did it myself, only took a few hours of messing around with the shape using a cardboard template. I also put a 1/4 inch bead of silicon around each hole so water does not run in in the rain. I have not seen any water get in yet so Im not worried about that at all.
There is pics somewhere on here from a couple of months ago.
