rack and pinion and rear differential. need some advice and help
Hi! I have a problem with the rack and pinion and the rear differential. Whenever i go faster i hear something( sounds like a motor or an old car running) from the back. So I went to 2 auto shops. They said that it was the rack and pinion problem and some bearing on the rear differential. They quoted me for parts and labor for 2500. Can anyone help me find new parts (rack and pinion and rear differential) for a better price and a good quality. and for the labor too what should be the right price for it. Thanks in advance.
Not enough info. to help with anything. When you go faster than what?
The first thing to (usually) go in the rear diffs is the pinion shim, once that gets worn thin, you develope a a whine at highway speeds. Eventually you will cross the pinion gear with the ring teeth and toast your gear set, put metal shavings in the bearings and need a complete rebuild. If you just need the pinion shim replaced, that is a different story. If you have clunking, that's a different problem.
Pull the drain plug and change the rear diff fliud, when you do, inspect the gear lube to see what is in it. Of course all this depends on how many miles your truck has ????? and how much trailer towing you have done.
Speed reply
Please do not dig up OLD as dirt threads, this one was last posted in 08/10/10... that would be from 6.5 years ago......
You asked a question in the H3 section. Stick with that one. Plastering this board with repeat questions and digging up OLD stuff is not how forums work.
Please do not post in this thread again.
Dugrobin
01-29-2015 09:53 PM
change, diff, differatial, differenchial, differential, h3, hummer, labor, metal, pinion, problems, rack, rear, shavings, whine
