Procedure: How to replace the fron and turn signal bulb
Old 09-02-2009, 10:50 PM
MAXIMA_818's Avatar
Default Procedure: How to replace the fron and turn signal bulb
Here I will show you how to replace the bulb, since the dealier replace them around 75 dollar !!!! I traied to replace them my self.
Tools:
1- 10mm nut driver.
2- New bulb.
3- Your hand.
1-
2-
3-
4-
5-
6-
7-
8-
9-
10-
11- The picture down ( screw is locating under the headlight).
12-
I attached the picture if they are not appear.
Attached Thumbnails Procedure: How to replace the fron and turn signal bulb-1.jpg   Procedure: How to replace the fron and turn signal bulb-2.jpg   Procedure: How to replace the fron and turn signal bulb-3.jpg   Procedure: How to replace the fron and turn signal bulb-4.jpg   Procedure: How to replace the fron and turn signal bulb-5.jpg
Old 09-02-2009, 10:53 PM
MAXIMA_818's Avatar
****inue for attachment
Attached Thumbnails Procedure: How to replace the fron and turn signal bulb-6.jpg   Procedure: How to replace the fron and turn signal bulb-7.jpg   Procedure: How to replace the fron and turn signal bulb-8.jpg   Procedure: How to replace the fron and turn signal bulb-9.jpg   Procedure: How to replace the fron and turn signal bulb-10.jpg
Old 09-02-2009, 10:56 PM
MAXIMA_818's Avatar
continue of attachments
Attached Thumbnails Procedure: How to replace the fron and turn signal bulb-11.jpg   Procedure: How to replace the fron and turn signal bulb-12.jpg
Old 09-02-2009, 10:59 PM
IgottaH3again's Avatar
Thanks for the pics. I just purchased a black grille for my H3 and will also be swapping out the turn signal for a clear version. Your pictures will help considerably. BTW this is the first time I've seen side markers like that on the vehicle.
Old 09-02-2009, 11:50 PM
stonemiser's Avatar
Seems like a heck of a project just to replace some lights, but I'm sure for what the dealer charges, it's worth the little bit of extra work. Thanks for the write-up and pics. Good job.
Old 09-04-2009, 07:33 AM
achim1000's Avatar
Its the Southafrican H3.
MAXIMA_818, where are you from?
Old 09-05-2009, 03:34 AM
MAXIMA_818's Avatar
Originally Posted by achim1000
its the southafrican h3.
Maxima_818, where are you from?
from ksa
Old 09-05-2009, 08:00 AM
NJTEX's Avatar
Don't forget to remove the brush guard first. LOL
As long as you have the grill off it's also the perfect time to upgrade to dual tone horns.
Old 09-15-2009, 09:57 PM
MAXIMA_818's Avatar
Thanks NJTEX for your addition
Old 09-15-2009, 11:14 PM
dlinden200's Avatar
And also do a good cleaning of the radiator.
There is a rubber flap at the bottom of the radiator.
Mine was jam packed with dead crittters and rocks.
BTW, nice pics of the grill removal. It should be flagged as a keeper.
Quick Reply: Procedure: How to replace the fron and turn signal bulb
