Power Locks and Driver Side Window not working
#161
Thanks thanks thanks!!!!!!!!!!!!!!
#162
I cannot believe it!!
I've been reading and trying everything!! I tried the key fob trick, took the master switch for a walk, checked and wiggled the fuses, did everything I could do with the battery terminals (left the positive off / left the negative off / held them together) and even tried selecting the code by holding the lock switch and selecting lock 1 like it was suggested by someone a few pages back. What I did ( the last thing I was going to do before I scheduled an appointment at the dealership ) was done out of desperation. I took out the master switch and brought it inside. I held a blow dryer to it. After a few minutes I heard a 'click' (as was mentioned in a post on here). I couldn't believe it. I brought it out to the rig, plugged it in, started it. Extremely skeptical, I closed my eyes and hit the window switch- and it worked!!! I just installed a stereo system in my h3 (which caused the issue to begin with) and was nervous that it was going to get stolen with the window being wide open! Plus, I live I alaska and it's the end of October and 10-18 degrees out! I never leave feedback from the stuff I read online but since the info got me out of a trip to the dealership I felt obligated to share! Hope this helps someone!!
#163
Did you ever resolve the problem?
#164
Thanks.... where is the master switch?
I have a 2007 H3.....
#165
#166
Ok I just now had the same thing happen. Wifey called while at work and indicated the head light was burnt out. I stopped there and changed it and turned the lights on. I went to start it and it was dead that quickly. I jumped it and fine. She calls me later and says the drivers window wont go down and the locks don't work. All other windows work. So I click the lock button on the fob and the lights flash and horn sounds but does not lock. I checked fuses and fine. I unhooked the cables and touched them together put back on and same thing. I also read to leave cables unhooked for about 30 mins resets it. Have not tried that. I did notice that it sound sluggish when I turn it over like not a full charge battery. ANY IDEAS ?
#167
My idea is to have you go back to page one and start with each remedy there..... What I posted has worked for me every time.
Also, this condition can resolve itself, just like I explained previously, after 4-5 ignition cycles, assuming your battery is charged and you have a good connection at both terminals. If you are using the OEM battery terminal connectors, you do not have a good connection.
#168
Tired and Frustrated
Ok I unhooked the battery left it that way for an hour and same thing. Yes I am still using the factory battery post connectors. They are a neat design but it appears they are pretty cheap. So I hit my fob and lights flash but doors do not lock. start it and all the windows go down except the drivers. I was thinking about putting in a brand new battery from one of my 4 cars I do not drive and see what that does. Comments welcome.........
#169
Pulled fuse
Pulled fuse and having a nice cup of Columbian Supreme (Black and Strong) while crossing fingers. Next step will be cycling the motor. Take for a drive a few times.
#170
Nothing
Finished my coffee put the fuses back in and same problem. Pulled the PCM fuses waited for a few. Nothing, So I suppose take it for a drive a few times. Being -20 degrees for a few days kinda limits my ability to work on things.
