Pls help me... Should I buy this H3 ?
Hi, My boss asked me to sell his daughters h3, i put it on craigslist.
We are getting low ball offers. After my wife and I drove it, we are considering buying it as a weekend grocery getter.
The factory warranty recently ended, he had lots of things serviced, throttle body serviced supposedly very pricey. Just had new plugs, wires, battery, replaced front bearings, removed replaced rear sway bar.
It would be a spare car. It was so much fun with our two kids.
He will sell it to me for $9,500. I figure I could drive it 1-2 yrs and not lose to much money? What do you think ?
We live just outside Chicago.
Wife drives 2010 Cadillac SRX, I drive 2014 Nissan Altima.
If you were me, Should I buy this for $9,500 ?
2006 Hummer H3 EXCELLENT
Also I called and got there service history.. Here is what the dealer did.
09/29/2011 211163 ZREG----Regular Vehicle Transaction N2154 - Rear Side Door Window Switch Replacement 75,607 MI
09/29/2011 211163 ZREG----Regular Vehicle Transaction K9804 - Replace Plastic Mode Fork 75,607 MI
08/29/2011 210127 ZREG----Regular Vehicle Transaction B7010 - Emblem And/Or Nameplate - One - Replace 74,434 MI
08/29/2011 210127 ZREG----Regular Vehicle Transaction A1230 - Front Side Door Outer Panel Partial Refinish Color/Clear Coat 74,434 MI
08/29/2011 210127 ZREG----Regular Vehicle Transaction J0667 - Belt, Primary Accessory Drive - Replace 74,434 MI
08/29/2011 210127 ZREG----Regular Vehicle Transaction B2852 - Sunroof Housing Front Drain Hose Replacement 74,434 MI
05/31/2011 207044 ZREG----Regular Vehicle Transaction E0722 - Tire Pressure Indicator Sensor Replacement 70,818 MI
05/31/2011 207044 ZREG----Regular Vehicle Transaction K7121 - Oil Pump Replacement 70,818 MI
05/31/2011 207044 ZREG----Regular Vehicle Transaction K4126 - Transfer Case Two/Four Wheel Drive Actuator Replacement 70,818 MI
11/12/2010 200362 ZREG----Regular Vehicle Transaction J0820 - Camshaft Timing Chain Replacement 62,625 MI
11/12/2010 200362 ZREG----Regular Vehicle Transaction J0518 - Cylinder Head Replacement 62,625 MI
11/10/2010 2073158 ZREG----Regular Vehicle Transaction N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 62,602 MI
11/08/2010 200107 ZREG----Regular Vehicle Transaction N4180 - Instrument Cluster Replacement 62,602 MI
11/08/2010 200107 ZREG----Regular Vehicle Transaction N2117 - Switch - Switch Module, Front Door - Left - Replace 62,602 MI
11/08/2010 200107 ZREG----Regular Vehicle Transaction L1200 - Fuel Tank Fuel Pump Module Replacement 62,602 MI
08/17/2010 196862 ZREG----Regular Vehicle Transaction J9991 - Customer Concern Not Duplicated (CCND) - Engine Concern 58,648 MI
07/19/2010 195701 ZREG----Regular Vehicle Transaction B4413 - Hinge, Rear Door (Bolt On) - Left Upper - Replace 57,157 MI
07/19/2010 195701 ZREG----Regular Vehicle Transaction J0251 - Intake Manifold Gasket Replacement 57,157 MI
07/19/2010 195701 ZREG----Regular Vehicle Transaction E0722 - Tire Pressure Indicator Sensor Replacement 57,157 MI
05/17/2010 192893 ZREG----Regular Vehicle Transaction F1200 - Propeller Shaft, Front Of Transfer Case - Replace 53,387 MI
05/10/2010 192636 ZREG----Regular Vehicle Transaction J4345 - Coil, Electronic Ignition Control (DIS/3CI) - Replace 53,349 MI
05/10/2010 192636 ZFAT----Field Action Recall V2253 - 10088 - Hood Grille Service Repair - Dealer Repair 53,349 MI
05/10/2010 192636 ZREG----Regular Vehicle Transaction J0518 - Cylinder Head Replacement 53,349 MI
03/22/2010 190977 ZREG----Regular Vehicle Transaction B0766 - Front Wheelhouse Liner Replacement 50,949 MI
03/22/2010 190977 ZREG----Regular Vehicle Transaction E9475 - Wheel, Bead Seat Repair 50,949 MI
03/22/2010 190977 ZREG----Regular Vehicle Transaction E1104 - Cushion Upper And/Or Shim, Body (Left) - R&R Or Replace 50,949 MI
03/22/2010 190977 ZREG----Regular Vehicle Transaction K6560 - Valve Body, Transmission - R&R Or Replace 50,949 MI
02/01/2010 189174 ZREG----Regular Vehicle Transaction J4345 - Coil, Electronic Ignition Control (DIS/3CI) - Replace 48,600 MI
02/01/2010 189174 ZREG----Regular Vehicle Transaction D0362 - Heater and Air Conditioning Control Replacement 48,600 MI
02/01/2010 189174 ZREG----Regular Vehicle Transaction B4472 - Rear Side Door Check Link Replacement 48,600 MI
02/01/2010 189174 ZREG----Regular Vehicle Transaction J6441 - Evaporative Emission Canister Vent Solenoid Valve Replacement 48,600 MI
02/01/2010 189174 ZREG----Regular Vehicle Transaction J6354 - Powertrain Control Module Engine Reprogramming with SPS 48,600 MI
06/10/2009 180490 ZREG----Regular Vehicle Transaction J5645 - Injector, Fuel - Diagnosis 33,537 MI
06/10/2009 180490 ZREG----Regular Vehicle Transaction N2184 - Switch - Door Jamb - Right Rear - Replace 33,537 MI
06/10/2009 180490 ZREG----Regular Vehicle Transaction N2185 - Switch - Door Jamb - Left Rear - Replace 33,537 MI
06/10/2009 180490 ZREG----Regular Vehicle Transaction N2188 - Rear Door Jamb Switch Replacement 33,537 MI
06/10/2009 180490 ZREG----Regular Vehicle Transaction B5939 - Liftgate Latch Striker Replacement 33,537 MI
06/10/2009 180490 ZREG----Regular Vehicle Transaction B4156 - Outside Rearview Mirror Replacement - Left Side 33,537 MI
09/10/2008 170036 ZREG----Regular Vehicle Transaction J6441 - Evaporative Emission Canister Vent Solenoid Valve Replacement 24,715 MI
09/10/2008 170036 ZREG----Regular Vehicle Transaction C2710 - Latch, Console Compartment - Adjust Or Replace 24,715 MI
09/10/2008 170036 ZREG----Regular Vehicle Transaction B9795 - Replace Left Roof Rack Rail 24,715 MI
09/10/2008 170036 ZREG----Regular Vehicle Transaction B9796 - Replace Right Roof Rack Rail 24,715 MI
09/10/2008 170036 ZREG----Regular Vehicle Transaction Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 24,715 MI
10/30/2007 014631 ZREG----Regular Vehicle Transaction B4051 - Link Or Spring, Front Door Hold Open - Left - Replace 22,913 MI
10/30/2007 014631 ZREG----Regular Vehicle Transaction E0716 - Diagnostic System Check - Tire Pressure Monitoring 22,913 MI
12/15/2006 598856 ZREG----Regular Vehicle Transaction N0760 - Tail Lamp Bulb Replacement 12,939 MI
01/19/2006 723523 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time
Just curious what was done to the throttle body? A throttle body service should be done about once a year if I remember correctly. I did mine every six months because we put so many miles on it. Takes less than 20 minutes and costs about 5 bucks to do yourself. So I'm not sure what he did to the throttle body to make that service expensive unless he replaced the throttle body
It looks like they took car e of it. They took it in to the dealer to get everything fixed under warranty. Looks like all of the standard 06 H3 issues have been addressed.
The rig looks clean and the price is very nice.
Please, don't listen to H3Ray. He has some issues with a used vehicle. He didn't know the previous owner or how it was taken care of.
+1 Provenance is everything!
Our '06 bought new was still cherry even at the 160k mile mark when it was totalled do to an accident. No real issues with it other than the typical H3 teething pain weaknesses all fixed under warranty, It's replacement, a very low mileage '09 that was used as a promo vehicle for a local club/restaurant, hasn't been as kind. On the positive side, all of it's problems so far are due to the previous owner installing every single accessory ever developed for these trucks. The aftermarket warranty we purchased along with it paid for itself already during our first year of ownership.
Ditch your Altima, buy the H3 and also pick up a matching yellow Solstice GXP so you can have year round driving fun regardless of conditions!
