Noise in front right area
Hope someone can help. My 2096 hummer h3 has developed a clunking/knocking noise while car is in drive but stopped like at a red light. I got no warning indicators or anything from the dash. Still drives fine I sense no binding or anything. Only hear noise while in drive and stopped. Any suggestions would be helpful. Thank you!
I'll take a look however it does not sound like a heat shield problem. I was low on oil so I added two quarts and it seemed to help but sound is still there. Might be time to flush tranny as it has not been done yet. Just turned 71k miles so it's probably time. Thanks to all who replied
If you search out you complaint, you would find that the majority of the time it turns out to be either an exhaust manifold heat shield (right side of motor) or CAT heat shield (right side of vehicle).
I would be more concerned about going 2Qts down in between oil changes than a noise. Mine never burns a drop.
Good luck.
Good luck.
Gomer,
Mine too has begun burning oil. With all the other issues the vehicles been having, I've been told it's symptoms of a bad cylinder head. Havent performed compression test yet, but I figured I share that with you. Mine is a 2006 as well.
Sad as a heck
Wow this was 2 years ago. I'll give ya an update. The clunking was my catalytic conveter that went out or whatever they do. Took it to dealer and they said I also needed a exhaust manifold also as mine was cracked. Not sure I believed them but had them change it anyway. Then I had a cheaper shop replace the converter under the passenger side. All was good for a while then had to get a new transmission as that went out as well. As of today all is well and running like a champ.
rifsm1
06-22-2017 08:45 PM
TowDawg
10-23-2011 05:15 PM
H3DONIST
05-25-2010 03:15 PM
parmstrong
01-25-2008 12:33 AM
