New Hummer, Question about Alarm.
Old 06-30-2007, 02:08 PM
Default RE: New Hummer, Question about Alarm.
ORIGINAL: Hummer Guy
Factory alarm is relatively worthless...but many would say most car alarms are. Most car thieves are pros these days, so alarm or not, they're going to take it. Some folks on here may have systems they like....
I disagree Brian..The Hummer's alarm is more than adequate. Once someone got past the doors by disabling the horns.... (there should also able a hood sensor and a volumetric cabin sensor to really make it good), they would have to punch out the ignition switch, but that would be fruitless too, because they wouldn't be able to crank it over because of the immobilizer system, which as you know requires the correct key in proximity to the sensor...Besides all that, it would take too long and be very discouraging to *** with..So the Hummer's stock alarm is quite sufficient.
Old 06-30-2007, 06:39 PM
WELL TALKING ABOUT THE ALARM..MINE WENT OFF AT 3AM ONE MORNING..HOME ALONE..AND MAN IT SCARED THE SHI! OUT OF ME..I THOUGHT IT WAS PRETTY DAMN LOAD.
Old 06-30-2007, 06:41 PM
OH SORRY..FORGOT TO MENTION..WELCOME TO THE FORUM AND CAN'T WAIT TO SEE PICTURES.
Nick119's Avatar
HummBob how much did that alarm system run you? And where did you purchase/have it installed? Thanks a lot for the informative posts!
BTW HummBob, your truck is unbelievable. Do you have any instant messanging programs?
Old 06-30-2007, 08:12 PM
Nick119's Avatar
http://www.element-119.com/H3 - Check out the pics and let me know what you think!
Old 06-30-2007, 08:23 PM
blackstangs281's Avatar
ORIGINAL: H34 pleasure
What made it go off?
Old 06-30-2007, 08:31 PM
BassGear's Avatar
ORIGINAL: HummBob
I AGREE!!! The factory alarms on ANY VEHICLES SUCK!!! That's why there are so many aftermarket ones!
Yo Nick!!! Congrats on the Rig!!!
You're in NY, so you should look into and Alarm/Car Starter deal!!
I have a Compustar Pro P2W9000FMR!!! It's AWESOME and COOL!!
[align=center][/align][/align]
Up to 3000* feet of Range
This new CompuStar Pro 2W9000FMR remote has a built in clock, in-vehicle temperature readout, and battery voltage sensing. This system operates at a higher frequency to allow for greater range and battery life. Firstech engineers were the first to perfect 900MHz FM for vehicle security applications and we've taken this technology to the next level with the 2W9000FMR Pro.
*Range is quoted for U.S. models only. International models will differ in range.
Includes 1 x Two-Way and 1 x One-Way remote
View the manual for the P2W900FMR
View the manual for the P1W900FMR
[/align]
Pro Remote Features
- Two-way paging remote
- New multi-color LCD (liquid crystal display)
- CompuGlow backlight
- Vibration and audible notification
- Clock display with alarm
- Internal vehicle temperature display
- Parking Meter timer
- Button lock
- Timer Start Mode
- Cold and hot starting with temperature
- Run-time indicator (extendable with remote)
- Turbo Timer (extendable with remote)
- Secure Auxiliary Mode
- Shock sensor on/off through remote
- Passive mode on/off through remote
- Valet mode on/off through remote
- Uses standard AAA 1.5 volt battery
[/align]
Pro Starter Features | P2W9000FM-S
Pro Alarm/Start Features | P2W9000FM-AS
[/align]
- Includes anti-grind and optional starter-kill relay
Factory Style Alarm, monitors doors and trunk
- Time start set on remote by user
- Optional external Siren (six-tone)
- Optional super bright blue LED
- Driver's priority unlock
- Ignition controlled door locks
- Secure valet switch
- 2-auxillary outputs, expandable to 7 with Channel Expander
- 2-programmable inputs
- Selectable trunk release output
- Programmable horn honk output
- Horn trigger output
- Diesel timer built-in
- Manual transmission compatible
[/align]
- Includes anti-grind and starter-kill relay
Battery backup capable
- External Siren (six-tone)
- Includes dual stage shock sensor
- Anti-Jacking mode
- Remote Paging System (can unlock vehicle via pin code)
[/align]
Geeezz...
That alarm has got it all and then some!
Leave it to HummBob to find the good stuff
Old 06-30-2007, 08:41 PM
ORIGINAL: blackstangs281
I'm not sure..we were having a storm that night..I called the dealership and they said they are not sure why either, but if it happens again to call..he did say there were a lot of problems with the 06 going off due to the back hatch not being latched proberly..but so far no problem with the 07.
Old 07-01-2007, 02:55 AM
ORIGINAL: Nick119
Thanks Nick!! I REALLY appreciate it!!!
After checking my invoice, it was right around $700 Canadian with taxes and installation. I had to installed at my Dealer actually!!! They sell/service two different brands of car alarm/starters.
Maybe call the 1-888 # to find someone local. Here's the info:
Consumers in the US
Please contact us Monday through Friday - 8 AM through 5 PM Pacific Standard to locate a dealer in your area.
Firstech LLC.
Toll Free: 888.820.3690
Main Line: 206.957.3780
Main Fax: 206.957.3330
Email:
Dealer Locator
Old 07-01-2007, 03:01 AM
ORIGINAL: BassGear
ORIGINAL: HummBob
[/align]
Pro Remote Features
- Button lock
- Timer Start Mode
[/align]
[/align]
[/align]
- Anti-Jacking mode
[/align]
Geeezz...
THANKS!!!! Yeah, IT's AWESOME!!!
The tech at my dealer has
Quick Reply: New Hummer, Question about Alarm.
