Lightbar/ torsion lift /
It has at least 4 inches on either side. Due to the length of the brackets it allows air flow above it. Maybe 3/4 inch space there. I will add some more pics today. That is a $53 lightbar from Ebay that came with the switch and relay
This is a 22 inch long bar. I'm not real proud of the hardware I used. Or the fact it is visible. The bolts are actually under the the top grill. Didn't have to drill or remove the grill tho. U see watch there is a small square hole already in the metal bumper. I took a screwdriver and heated and bent it 90 degrees. Got it red hot and melted thru the plastic out bumper. Now I had a thru hole to hang my bolts. Don't think I'm going to modify or even reinstall the lower grill at all.
aaronh3
01-23-2012 10:18 PM
kshummer
12-09-2011 06:07 PM
LoJac963
08-05-2011 10:19 AM
Nxsov180db
05-01-2008 09:38 PM
