Let's hear your high milage testimonials
  #51
Old 02-05-2016, 12:57 PM
Mkawas's Avatar
108K miles on my '06 H3 ADV, without major issues. Just replaced the T-Case chain... I need to replace the High Pressure steering hose, and the Driveshaft slider.
  #52
Old 02-06-2016, 03:09 PM
motion vega's Avatar
Default Traded at 160
Traded it to woodfield Lexus on a 2011 qx56 and zero regrets. Needed something bigger, and was tired of the clearance lights vibrating. If anyone ended up with it message me and I can fill in the history
  #53
Old 02-10-2016, 11:12 PM
septembers0wn's Avatar
Default good news
101000 never did anything but oil and brakes . also feel as tf case chain is getting some slack though. no codes no fires no vibrations.
  #54
Old 02-11-2016, 11:39 AM
choochmalooch's Avatar
Cool
I got mine two years ago with 58K on it. Had the same clearance light vibration. Took them off, added the GM fix "stiffeners" and changed the foam seal around them and haven't had the problem since, Just broke 88K. Other than that I did the radiator and I have a TPMS with a dead battery.
  #55
Old 02-21-2016, 01:08 AM
brash47's Avatar
2006 H3 Adventure Package. I purchased in the first week of release. I supposedly have the group with the bad engines. I never had a problem with the engine.
I now have 240k miles on the truck. Other than standard maintenance, until I hit 210k, I didn't have any issues. At that time, I had a cylinder go bad. The dealer told me...2k to fix...but, 4.5k brand new crate engine installed with 100k warranty. I chose the engine.
The truck runs like new and I haven't had any more mechanical problems until today. I received the "Traction Control Failed, service soon" signal. My 4x4 control panel has no lights other than the airbag lights. The truck still runs fine. I'm trying to figure out what will be the fix on this one.
All in all, I have gotten my money's worth and will continue to get it. I love this truck!
brash
  #56
Old 03-13-2016, 08:21 PM
wixomhead's Avatar
152,000 hwy miles 2006 H3
Base model, no leather, no monsoon, no sunroof.
Third owner, bought from dealer with 41K. Head done by previous owner under warranty
Replaced xfer case solenoid under warranty soon after purchase
Replaced radiator (hairline crack across top) arond 100K, cam position sensor around 120K, 4 x speakers, battery, 4 x rotors, 4 x calipers, e-brake cable, Heat/blower/vent lights 2 x. Just replaced exh manifold (catalytic separated) + O2 ($1500, went with OEM from dealer)
Set of Wrangler ST-As at 80K along with every fluid in the truck. Due for another set now.
Oil and filter changed every 5K (cheapest 5W-30, usually generic Advance Auto store brand)
  #57
Old 03-14-2016, 05:02 PM
SculptorMJM's Avatar
2006 Adventure 170k. Also have an early release with the bad #3 cylinder issues. Past month starting to overheat. Oil light coming on. Rough idle. Burning oil pretty bad. Looking into all of that now. Previous maint: Thermostat, Catalytic converter, Exhaust manifold - biggest mess.
  #58
Old 09-12-2016, 11:23 PM
AR15wheeler's Avatar
165,000. Just had the rear main go out. No problems beside that in the past 40,000. I'm also rolling on Cooper tires that have 70,000 miles on them and look greAt still
  #59
Old 12-14-2016, 10:16 PM
HighmileageH3's Avatar
2006 h3 adventure package. 211,000 miles and going strong. Original inline 5 engine. Manual transmission. Original clutch
  #60
Old 12-15-2016, 11:43 AM
canman's Avatar
Originally Posted by Nmocean
I have a 105k on mine no major issues runs great
I have a 2006 h3 298,000 kil. motor and trans have never been touched .
Quick Reply: Let's hear your high milage testimonials
