knocking/grinding - Hummer Forums - Enthusiast Forum for Hummer Owners
Reply
LinkBack Thread Tools Search this Thread
Old 12-30-2012, 12:51 PM
lostsoul77's Avatar
Exclamation knocking/grinding
Hey all,
I'm having an issue which began 2 days ago when we got hit with our first snow storm here in Pittsburgh. Seems to have started shortly after engaging and disengaging the 4Lock (4hi). I've noticed a knocking/grinding noise while driving or coasting and mostly when turning right or going around a bend which goes to the right; also noticeable when in 4Lock. Any Ideas? It's difficult to tell when the 4Lock or 4Low engages or disengages, as I don't hear anything and can only tell by the feel (truck seems to hold back). I'm worried that it is not completely disengaging and that gears are gettinng chewed up or that I something else seriously about to go wrong with my drivetrain. 2007 H3 3.7L I5 non-adventure model.
Old 12-30-2012, 10:15 PM
I have a very similar issue on my 06. If i do a sudden right turn at low speeds I get a clunking/grinding noise. Feels like it is coming from under the driver side floor panel. Seems to only occur in the winter. Its been getting really bad lately.
Old 12-31-2012, 01:42 AM
mavrk73's Avatar
I had a similar clunking noise under the driver side floor panel, I'd let off the throttle then stab it, that's when I would hear it. Took it in to dealer since it's still under warranty, Ended up being the front diff mount bushings.
Old 12-31-2012, 09:35 AM
lostsoul77's Avatar
Mavrk73,
That is exactly what's going on. The noise is directly under the drivers side door and more prevalent when making a right turn, when driving straight, I can hear and feel it a little bit, also beginning to hear squealing and clicking.
Old 12-31-2012, 10:06 AM
lostsoul77's Avatar
Question
I have the Chrysler Powertrain Care Plus warranty which appears to cover everything powertrain related up to 120k miles or 5yrs. I have 94k on it now (purchased almost 2yrs ago with 50,010 from a dodge dealer). Is it safe to drive in this condition if it's the bushings? I've had to drive it to work and back home and don't have an appointment until Wednesday morning.
Old 12-31-2012, 11:12 AM
Lostsoul,
Can you please post an update when you find out what the issue is? Thanks!
Old 12-31-2012, 11:19 AM
lostsoul77's Avatar
Quote:
Originally Posted by chasekanter View Post
Lostsoul,
I sure will!
Old 01-02-2013, 01:08 PM
lostsoul77's Avatar
Arrow
front right wheel bearing is bad, wheel almost sheared off! 650.00
extended warranty only covers FWD and not 4x4 or AWD. what
a waste of money....
Old 01-02-2013, 03:22 PM
Well that is great news! What kind of tires do you have? I put on 315's about 2 years ago. That may have something to do with it.
Guess I need to set up an appointment to get it looked at. Ugh!
Old 01-03-2013, 09:49 AM
lostsoul77's Avatar
Wink
I'm running Cooper ZEON LTZ's 265/75R16.....great tire so far!
CooperTiresConsumer - Cooper Zeon LTZ<span class='trademark'></span>
Reply
Thread Thread Starter Forum Replies Last Post
Knocking noise from the rear rifsm1 Hummer H2 1 04-07-2011 12:06 PM
Knocking Sound WoogiesH2 General Hummer Talk 4 03-08-2011 10:58 AM
Knocking at cold start-up remedy! quadblaster240 Hummer H3 7 12-22-2009 03:25 PM
When you see this H2 rocking don't come knocking dilo2001gt Off Topic 11 04-11-2007 11:52 PM
knocking engine Guy Hummer H1 2 02-22-2007 11:21 AM
Tags
08, 2007, bearing, clunking, drivers, extend, floor, grinds, h3, hummer, noise, side, turn, warranty, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
