Hummer H3 Recall by GM
GM lists a phone number for Hummer. I called..Girl took my info. and VIN. Said letters will be going out. This is an EXPENSIVE repair if we have to pay for it. My '06 LUX. only has 29k miles, but it can happen anytime.. Members should contact dealers and stay on top of this..and report any progress...
I bought a resistor and wiring harness for 30 dollars brand new, installed it and repaired the burnt one for a backup. How much is the stealership charging for this entry level work?
Hope everyone is not getting confused. There are two problems, both ridiculous because GM uses cheap parts. These probs. are not Hummer specific and applies to Chev and GMAC trucks and some others that use the same cheap Chinese parts. The recall if the most hazardous and is the resistor in the ducting behind the glove box. A simple fix which can be found in the FORUM. The second prob. is the temp. control ****. This applies to cars and trucks across the GM line. When you turn the AC on full cold it works fine but if you begin to freeze your butt off and you turn the **** one or more clicks toward a more comfortable temp., nothing but very hot air comes out. This is also a very expensive dealer fix and it will happen again if OEM parts are used. A SATURN control module can be used and is cheaper. The cheapest and easiest way is DIY with a resistor from Radio Shack and an hours time. Directions with pics. is on the forum. Now if we could get GM to replace the worthless thermostat I could get rid of my check engine light.
I replaced the blower resistor harness twice (once for each vehicle). Cost me 200 bucks each time. I still have one of the replacements i storage.
My blower went out yesterday. I took it to the dealer this morning and they verified it was the resistor module and harness. Called GM customer support who said I have to pay for it out of pocket and when there is a fix under the recall they will reimburse me. $333.00 out the door this morning. Great customer support :-(
