How to remove H3 factory radio
It takes only a few minutes. First you need to remove the trim around the radio by sticking your fingers in the power outlets and pulling. It's just snapped in place and that is the best spot to grip. The bottom edge frees up first so you and usually wedge a finger under that and pop the rest out. Once it loose, unhook the wiring harness for the power outlets, etc. There are screws on each side of the headunit, remove them and pull it out.
Bob
HEHE, yea you may want to, but its not necessary. Not enough current in the power outlets to give you a shock. Well, unless you stick your tounge in there, but then you likely have bigger issues.
07TacticalH3
06-04-2010 05:28 PM
viper
09-15-2007 12:25 PM
RealJeep
08-15-2007 01:22 PM
maximuss32
01-27-2007 06:20 AM
timtran
07-18-2006 10:28 PM
