How do you change the rear brakes on a 06 Hummer H3?
Old 03-24-2012, 02:52 PM
Diz's Avatar
Diz
Diz is offline
Default How do you change the rear brakes on a 06 Hummer H3?
My buddy owns an 06 Hummer H3 and we changed out the front brake pads thanks to this awesome forum. For the life of us however we can't figure out how to change out the rear brakes. Help!! Thanking you in advance!
Old 03-24-2012, 03:48 PM
drtom's Avatar
Banned
you can download the h3 service manual in 5 minutes for 15 bucks, tells all. or maybe a pirated copy for less
its nap time ill check when i wake up,it you still dont have it!
Old 03-24-2012, 04:38 PM
Widespread Hummer's Avatar
Use the search function and you will probably find that your rear rotors also have a drum for the parking brakes. Look for an access spot in the backing plate. You can slack the brakes by turning the nut in there.
Old 03-24-2012, 07:10 PM
drtom's Avatar
Banned
its all in the cheap download. i cant look any longer,its the first drum brake stuff ive seen in years and i started breaking out in hives. allergy to those miserable springs and dozens of other unmentionables,,,
Old 08-16-2013, 12:53 PM
Peng's Avatar
Check the link below for break and rotor replacement with pictures.
BRAKE JOB Front Brakes
GBergie
08-26-2015 04:57 PM
ftc-garage
12-29-2012 08:38 AM
MeBelovinMyH3
11-03-2012 08:58 AM
thehammerh3
03-24-2009 05:46 PM
23window
01-03-2009 04:59 PM
Quick Reply: How do you change the rear brakes on a 06 Hummer H3?
