hood vent
hood vent
I am STRUGGLING removing the old hood vent which I am replacing. I couldnt find much in the search and I have "tugged" with zero luck. I see that there are 3 pins under the hood holding the old one on, I pushed those through, but still no luck. what am i missing?? thanks
There was a recall to correct the faux hood vents from flying off at Eway speed or in high velocity car wash dryers which was to glue them to the hood. If you truck had went through the recall, then what do you do to pull off something glued? You pull like a mad man, start at a back corner and get mean. No rocket science involved.
A little history: When the H3's were built the fake hood grille was only held on with some plastic clips under the hood. There was a recall issued because they were flying off; Especially in northern climates where water would run under them, freeze, separate the clips and turn the plastic grille into a big kite at 70 MPH. The remedy for this was for the dealer to glue them on with massive amounts of adhesive to keep them in place forever. Good luck getting it off in one piece.
ArizonaFeeds
09-16-2012 02:21 PM
jeffwhiteis
08-16-2011 08:59 AM
jeffwhiteis
07-24-2011 06:36 AM
jeffwhiteis
07-23-2011 07:05 AM
