Help with 2 CE Lights
Old 07-27-2014, 11:02 AM
Mr_Sandman's Avatar
Default Help with 2 CE Lights
These just popped up. I have a K&N intake/air filter system and thought when it would get dirty or the throttle body gets dirty that one of these would pop up, but just want to be sure that's the potential cause.
Here is what I am getting:
P0449
EVEP Emission Control System Vent Malf
P0171
System Too Lean
(Bank 1)
Old 07-27-2014, 08:44 PM
Year, engine and mileage?
Old 07-27-2014, 11:42 PM
Happy Hummer's Avatar
P0449 is the evap solenoid.
P0171
OBD-II DTC: P0171 System Too Lean (Bank 1)
Chris
Old 07-29-2014, 07:22 PM
Mr_Sandman's Avatar
2006 H3 Base, manual tranny, 95k miles. 5 cyl. Catalyst. K&N intake and filter. otherwise stock.
I need help understanding what problems these codes might indicate, like the evap solenoid. what the heck is that!
Old 07-29-2014, 07:44 PM
2 CE lights?
Replace the vent valve solenoid, cheap and easy fix. Then clean your maf sensor cheap fix too. Boom boom, out go the lights. GL
Old 08-01-2014, 12:11 PM
Mr_Sandman's Avatar
Called Oreilly -
They can order a canister vent solenoid or they have a vapor canister purge valve. Which is the correct part for the PO449 code?
One is $23 and the other $50.
Old 08-02-2014, 02:28 PM
First pull the connector to the vapor canister and check for voltage. Clean the **** out of the connector, the contacts and the canister side also. Then reconnect and see if you still have an issue.
If so then go to YouTube and look up the method for cleaning out the evap canister and filter before you spend any $ on replacing anything.
I chased this one for a while and it was corroded wires on the pigtail side. Nothing wrong with either solenoid nor canister.
bobopotato
27
07-30-2011 09:09 AM
pteam
09-08-2008 12:37 AM
schannel
08-17-2007 03:30 AM
Fallz
11-27-2006 04:03 AM
CruisinCarAudio
05-25-2006 04:14 AM
Quick Reply: Help with 2 CE Lights
