Headlight Switch
Headlight Switch
My headlight switch on my 08 H3 works but doesn't light up anymore. Is there an easy way to replace the bulb in it. I replaced the bulbs in my window switch but I don't see how the headlight switch comes apart. I don't want to take the whole dash apart just for that.
The headlight switch actually has 5 screws to remove the back cover and take it apart, and it has two bulbs inside.
Thanks Doc, you obviously know more about this subject than I do. Ill try and replace the bulbs this weekend. Looks like a real tight fit but its a pain in the neck not seeing the switch at night. Thanks for the help and Ill let you know how I made out when Im done.
