Headlight Switch
Old 12-22-2014, 09:35 AM
rayfry08's Avatar
Default Headlight Switch
My headlight switch on my 08 H3 works but doesn't light up anymore. Is there an easy way to replace the bulb in it. I replaced the bulbs in my window switch but I don't see how the headlight switch comes apart. I don't want to take the whole dash apart just for that.
Old 12-22-2014, 12:47 PM
Should have 4 screws on the back of it to take it apart.
Old 12-22-2014, 02:29 PM
rayfry08's Avatar
Just so you understand. Im talking about the headlight switch, not the headlight itself. Cant see anyway that it comes out.
Old 12-22-2014, 02:55 PM
Well that is a god thing, because the headlight itself does not have four screws in the back of it to take it apart.
The headlight switch actually has 5 screws to remove the back cover and take it apart, and it has two bulbs inside.
Old 12-23-2014, 07:34 AM
norinco3264's Avatar
Default god thing
What does Christ have to do with this? 😁 Hehheh
But thanks for the info, same light just went out for me.
Old 12-23-2014, 07:51 AM
rayfry08's Avatar
Thanks Doc, you obviously know more about this subject than I do. Ill try and replace the bulbs this weekend. Looks like a real tight fit but its a pain in the neck not seeing the switch at night. Thanks for the help and Ill let you know how I made out when Im done.
Old 12-23-2014, 09:45 AM
happythree's Avatar
im curious about this. i cant remember the last time i touched mine.
lights come on, they go off. i killed my drl fuse.
im happy with auto lights! no messing
Old 12-23-2014, 02:23 PM
rayfry08's Avatar
I also use the auto lights but I like things to work they way they are suppose to.
Old 12-23-2014, 03:48 PM
rascole's Avatar
Aren't they supposed to work in auto?
Old 12-28-2014, 07:30 AM
rayfry08's Avatar
How do you get to the back of the switch? Can't figure out how to remove lower valance below steering wheel. Is there some other way to get to it?
Quick Reply: Headlight Switch
