Wheel Spacers
Old 06-28-2011, 03:23 PM
rlad10's Avatar
Default Wheel Spacers
I'd like to put wheel spacers on my h3. Should I go with a 1", 1.5", or a 2" spacer? I don't want it to look too wide.
Old 06-28-2011, 06:46 PM
drtom's Avatar
Banned
id read a lot about them
Old 06-29-2011, 12:03 PM
Draketh's Avatar
It is best practice to avoid wheel spacers when at all possible. If you want to change your stance go with a set of wheels with a different backspacing.
The amount of force a 5,000lb vehicle exerts at the wheels in a corner at speed is massive, I've seen warped studs, cracked spacers, etc. Especially if you do any kind of even moderate offroading avoid spacers.
By the time you invest in a set of QUALITY spacers, you might as well just jump up to getting new wheels. When I considered it as option, the kind of spacers I would feel comfortable running were going to cost about $120 per wheel. You can get a new set of 16" wheels for around that, and a few bucks more gets you bigger wheels if you want.
Old 06-29-2011, 01:49 PM
Before advising you on this please let us know some things about your H3. It is hard to give advice if we don't know the reason/issues.
Can you tell us what you expect to gain from adding wheel spacers? Wider track, looks, performance, etc.
What size and brand tires are you currently running on your H3?
Do you have the OEM rims on your H3?
vinny
27
01-07-2011 08:11 AM
Brodie
11-05-2008 01:06 PM
chukwagen
02-18-2008 03:00 PM
wilsoada
12-07-2006 09:26 PM
Quick Reply: Wheel Spacers
