H3 Roof Rack
RE: H3 Roof Rack
ORIGINAL: Muddydawg75
I wish I would have seen this sooner.... but.... Let them know you are on this forum.... G-Style takes very good care of Hummer Forum members...
In the future go to the G-Style website first...
RE: H3 Roof Rack
ORIGINAL: Wrongway1
Well, unless I missed something, you still got the same product at a better deal by buying from them on ebay, than going through GStyle website by about $30.00. Right??
RE: H3 Roof Rack
Yes, if you go directly to the site and let them know that you are a member here they will give you a discount. I don't know how much due to the fact that I haven't bought anything there yet myself.
RE: H3 Roof Rack
One more point....when you go to install them, there are little plastic washers that sit in the bottom of the roof racks, and slide on the roof rails of your 3. The only issue I had, was that they liked to fall out before I could get the racks into the rail system. I used a little black silicone, and then put them in place on the roof racks, and then you can turn them over and put into place, with nothing falling off......Just a thought!
RE: H3 Roof Rack
ORIGINAL: solarflare
RE: H3 Roof Rack
UPDATE: okay so I got the roof racks from G-Style today. I opened the package noticed everything was there and it doesn't look that hard to install. So I begin doing it, nothing better to do. I put the screws into the mounts, but noticed the washer with the locking washer is just too damn hard to get onto the screw and put it into the mount. To save some real arm pain, I just put on the locking washers. Once you get those on, there is really no big issue getting them on the roof. When you get them to the start the one side falls in but the other will just hang on the lip. Pull the other side gently and it should fall in (almost feels like you might break it right off, but it will fit in). When they slide in I noticed they scratched the inside of the rails pretty badly. I tried to go easy with them, but they still did that. I am not even really sure why it scracthed. It seemed like everything was snug, but not rubbing the sides. another tip...when you put back the rubber guard that goes over the rail, put some WD40 or some oil on the inside of the rubber so it slides on better. If not, it will just bunch up.
Some tips with the letters if you order from GSTYLE...Take your time putting them up. You will thank yourself for this later. They are very tedious, but it looks good if they are all straight and even. The plastic that holds the glue is a pain to get off on the letters, but again take your time. Go from left to right (i,e put H then U then M and so on) this makes it easier to line them up with each other.
Anyways I will add some pics later when I charge the camera batteries..[:@]
