H3 performance question?
#41
That is the air pump inlet tube going into the side of the OEM air filter box for the 2007 only, it draws from the box and requires no filter. The reason K&N uses that little cone on their intake kit for the 07 is they bastardized the system to make it "open" and had to put something over the end of the exposed air pump inlet and connect it to something so it does not fall over into the radiator or belt.
#42
The stock air box does not need or use that little cone, go have look under your hood.
#43
okay so everything installed, almost everything ordered. i just need to contact james for throttle body, and then a tune and should be good to go thanks guys for all the awesome help. i have another question about something else but i will create a thread in the right section
Caraddict
12-12-2011 06:55 AM
ezmoney92
04-25-2009 01:39 PM
NIK1
05-03-2008 08:48 AM
